Single AA battery to light WHITE LED for long-long time
Started by zon, March 05, 2008, 05:18:40 AM
zon
Here is my latest trial.
It's works. The battery not drain anymore. :)
Thanks GOD.
Maybe, Energy enter to system come from 3 of NE2 bulb (see pict)
Replicate it !
zon
gyulasun
Quote from: zon on April 28, 2008, 10:57:37 PM
Thanks GOD.
Replicate it !
zon
Hi Zon,
Thanks for this circuit.  I would like to ask how long the battery "not drain anymore"?
Do you monitor the current consumption from the battery by a multimeter?  If yes, do you see any change in battery current when you remove one or all three Neon bulbs?
Are the Neon bulbs faintly lit or they remain dark?  How many white LEDs do you use now?
Here is some good info on Neon bulbs and on NE-2 too:  http://en.wikipedia.org/wiki/Neon_bulb
They have a negative resistance characterictic when they reach the so called striking voltage limit and current starts flowing in the noble gas inside the bulb, usually this voltage is around 85-90V or higher. Below this voltage the bulb is an open circuit just like an air gap.
Sorry for the many questions... ;)
rgds,  Gyula
hartiberlin
Thanks GOD.
Replicate it !
zon
That is very interesting.
Could you please also post a few pictures of your coils
setup ?
As the LED would shortout the Neon bulbs at around 2.7 Volts
I wonder, how they get the power into the circuit ?
But gas discharges also played a major role in the Chernetski
device, so maybe this is a small version
of a Chernetski device ?
amigo
I don't get it, is the NE2 lit or not in that photo?
I mean that's a pretty good step-up from 1.2v to 70v if you got the NE2 to light up, especially three of them...
zon
Sorry, here is my latest trial, revision number 14.
Measurement at + battery, 3.6 mA
The battery still drain in certain time but improve the duration.
What i do is combining my circuit with my friend's free energy charging (FEC) system.
I share FEC'S my friend pict.
Component are :
    3 pcs NE2
    4 pcs Diode 6A2
    6 toys magnet (Rattlesnake sound eggs, made in China)
    Coil SWG 35, 0.2130 mm
    Capacitor 4700uF/25V
    Capacitor 100 nF
    Ferit (not torroid)
Unfortunantly, my friend's not allowed me to share coil setup.
I have try use FEC to charge LEAD ACID BATTERY 6 V 4AH and 12 V 3.5AH.
It's work ! no tricky
It's encourage me to combining with my circuit and guest the coil setup.
If i got it by my self , i will share it
zon
