Kicks explained
Started by sparks, March 16, 2008, 01:01:22 PM
poynt99
Quote from: infringer on April 12, 2008, 10:05:12 PM
Poynt99 you are talking plain english... besides I'd rather be a horse then a sheep!
;D I'm trying to set an example
anyway, all due respect grumpy, but electron flow is involved in at least one step along the way, and this thread is about the test SM explained we need to do to discover the secret.
@infringer
at least you tried, doubt if any others will.
it has more to do with the events that happen with the test. the kick is a slight increase in current, and a slight movement in the wire. The movement is straight forward, the increase in current is not so easy. Current results in flux. Think about the sequence of events. The key elements are in my last post.
spherics mentioned two ways to create a kick, SM mentioned yet another. all 3 methods apparently yield an increase in the mag field. i personally can't explain for sure what spherics was trying to say, and no one else has been able to yet.
any takers?
Grumpy
Quote from: infringer on April 12, 2008, 11:12:04 PM
@grumpy
So essintailly the main component to manipulate here is what magnetic flux.
Manipulation in magnetic flux again is done either with degausing coils or circuits this is the only time I really hear/feel kicks other then in generators...
Grumpy I wish you would place your theory on what we are trying to accomplish...
As well as possibly a design that you would use to achive the theory you seem like a smart guy just tired of all the random speculation... And false positives possibly IDK man I obviously havent been around OU.com for the duration like you may have so I have not been able to see some of your more informative posts.
But I suppose this one is a better start then none. Thanks Grumpy
Dielectric flux - not magnetic flux - at least this is what Eric Dollard called it.  His theory is available in his books.
As fr designs - the designs of Eric Dollard, Richard Hull, and Tesla are readily available.  RH persued long sparks so this is not really what we want but a good load of info on a take of Tesla's work.
I have deleted most of my posts - to the dismay of many - just something I feel the need to do periodically.
Quote from: poynt99 on April 12, 2008, 11:37:20 PM
@infringer
any takers?
It does not matter Christ himself told you to stand on your head to know the secret, if you can not see it , then you can not see it.
How is the "kick" an increase in current when it is detected on an Oscope which measures voltage?
EDIT:
Didn't SM say that the only difference between Tesla's technology and his was that he (SM) fed a small amount back into the circuit?  Yet everyone is running in a circle...
        -Frank Edwards
poynt99
Quote from: Grumpy on April 13, 2008, 12:20:20 AM
Are they not directly related?
mag fields (magnetic flux) result from current. spheric talks about a COMP field which for all intents and purposes (paraphrasing him), is an increased magnetic field due to the bifilar coil and topology.
SM clues us in twice that the kick is really and increase in current. he also alludes to the movement.
so I don't see where the confusion is?... it's easier to measure a voltage than a current, esp. for most people. no doubt spherics said use a scope to measure the coil voltage for this reason.
QuoteDidn't SM say that the only difference between Tesla's technology and his was that he (SM) fed a small amount back into the circuit?
I don't know if SM said that or not. paste it here if he did pls. are you saying that the TPU is RE-based?
sparks
   I believe that the kick creates a fleeting scalar wave where the voltage and magnetic field are propogated in geometric unity.  This field stands still in space.
The rest of the Earth just keeps on truckin and whatever is nearby collides with it.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
aleks
Sorry to repeat it again, but why not take acoustics into consideration? Electric spike strikes atomic lattice. This is called phonon interaction. Phonons are slow: 3800m/s in copper. While electrons are fast (50000km/s). What does that mean? It means that there are a lot of phonon (pressure) non-equilibriums (singularities) appear in the copper's lattice. These non-equilibriums have to be "dissolved" and until they dissolve as impact waves, there is what I call a DC acoustic wave formation exists. This formation is what produces gravity/anti-gravity gradient that at the same time represents a potential gradient for charges, which is seen as "sine wave segments" on the o-scope in Otto's work.
