Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
poynt99
Since spheric has declined to clarify his design in relation to the original SM design, I'll take a stab at describing what I think he is really trying to say:
With all 4 poles oriented and fired as he shows in the diagram, i.e. all N-poles facing inward, there will be a repulsion or bucking of fields in such a way that the vector sum of each coil pair creates crudely a rotating magnetic mono-pole (RMMP) of sorts, mostly in the horizontal plane. Due to the mutual angle of the bucking fields, the resultant field extends outside the perimeter of coils XYZ.
In SM's design (presumably), as with Tesla's seminal insight alike, the RMF created is a rotating magnetic di-pole (RMDP), mostly in the horizontal plane.
So maybe a RMMP is spherics' goal as opposed to the 'less efficient' RMDP?
i.e. Does a RMMP create a vortexing aether field more efficiently than a RMDP does?
thanks for your latest post spherics.
Bruce_TPU
Quote from: spherics on March 24, 2008, 11:56:27 AM
The SM designs all work on the same set of principles. A pulse into a coil generates an expanding magnetic field. The magnetic field comes into being by an underlying patterning of the ether. It is a cascade action on the part of the ether that causes the EFFECT of an expanding magnetic field. If you then cause a second magnetic field to expand through the same space as the already expanding magnetic field, a specific cascading action, a pattern is setup in the ether which is the EQUIVALENT of a magnetic field and has many of the characteristics of a magnetic field. By this I mean it will interact with metals, and cause the EFFECT of a current, IF the field is moving across the metal.  I will refer to this field as a COMP field from now on. But please be clear this COMP field is in addition to the expected magnetic field. This COMP field, a patterning in the ether, is dampened and effectively nulled by magnetic metals. This is why if you are using an iron core in the coils named control coils you will never get a working TPU.
No doubt this may be disconcerting to many who have fond references to baling wire, iron wire and the like. I will now digress onto the circumstance surrounding the initial eureka moment as I understand them. Audiophiles who frequent this watering-hole will no doubt have heard of QUAD ESL electrostatic speakers. An essential design element is the incoming signal is sent into, I believe, 7 or 8 progressive delay elements. These elements delay the signal by microseconds each time.
As part of experiments, associated with what would become his 3D spacial control patents, he was using these delay elements with custom made bifilar wound voice coils (i.e. air coils) and unexpectedly detected an anomolous signal on his spectrum analyser.
Steven Mark created his own delay elements using iron wire after several years of intermittent experimentation. The technique was to carefully wrap a bifilar air-coil using copper wire. The longer the length of copper the better but using identical lengths. The two coils were connected to the SAME pulse waveforms in parallel so that the magnetic field is additive NOT cancelling. The delay element was added in series to only one of the coils that made up the bifilar coil. The delay coil was made from insulated iron wire wound into an air coil. An oscilloscope was connected to both COPPER coils. The setup would be pulsed with a dc offset square wave (i.e. 0 to 20V not -10 to 10V) at the resonant frequency of the bifilar coils. The tuning consisted of cutting the iron wire down in length until an unexpected pulse/signal appeared. This pulse is the kick. I will refer to these tuned bifilar coils as kick coils.
You are privy to the information that the COMP field is nulled by iron. Those who so wish may like to take some time to fully comprehend the frustrations of closely packing the delay and bifilar coils together only to find the unexpected pulse was no longer appearing!!!  This is what SM had to contend. And Jack says SM was not technical. Bunkum!!
From traditional electrical engineering view point the kick coils for a particular quantity of energy now put out the expected magnetic field but also put out the COMP field which has effects like a magnetic field. In a world that excludes the ether, these coils are overunity. If the world took into account the ether, then the coils would not be thought of as overunity.
The magnetic field is now larger than expected. All that needs to be done is to rotate this field in a circle and intercept the field with an output coil. The captured energy is greater than the input energy because of the energy apparently created by the COMP field. If you arrange all N poles of the kicker coils so that they point towards the center and pulse each coil in turn you will get a rotating magnetic field. There are many ways to create a rotating magnetic field. A secondary effect of a rotating field is the entrainment of the COMP field so that the pattern in the ether is partially additive. A big problem was the iron in the delay coils. It was found that a large solenoid fed with a DC current to produce a static magnetic field around all of the kicker coils allowed the kicker coils to be tuned with the iron delay coils in close proximity.
Intercepting only N poles of the kicker coils means you get a DC output along with a smaller induced ripple from pulsing the kicker coils.
Feedback of the output into the input was achieved using toroidal saturable inductor switches. I've copied the picture from other messages of the inductor switches. Refer to the patent for an example to see how these switches are used. Early designs used a small magnet to bias the saturable inductors.
All SM devices had small batteries to power the LC oscillators. The LC oscillators were used as control pulse currents to the saturable inductors. To start the process high voltage capacitors were step charged, this is why the coils took time to start-up! The first few pulses came from these pre-charged capacitors being switched via saturable inductors. Part of the DC output was feedback to keep the capacitors fully charged.
My design shown at the very start of this message thread eliminated the need for an iron delay coil because the pattern is set up in the ether outside of the influence of copper metal of the control coils. It directly allows the COMP field to be generated IN FREE SPACE. By placing the output toroidal coil within this free space the COMP field is intercepted. The complete lack of any magnetic materials within this design is what allows this to happen.
I do believe there are elements of information here that you will not have been aware of before. I trust this is enough to convince at least some of you to reflect and ponder more seriously on this material.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19820016542_1982016542.pdf
poynt99
QuoteIntercepting only N poles of the kicker coils means you get a DC output along with a smaller induced ripple from pulsing the kicker coils.
Yes Bruce this would account for the mainly DC output, which is why I explained the rotating field as similar to a mono-pole.
As you are a man that seems to have a lot of the answers, how does the rotating di-polar field in SM's device account for this DC output?
Grumpy
You are all missing many peices of the puzzle and trying to put it together anyway.
The goal here, as will many devices, unbeknownced to the inventer, is to manipulate what spherics has termed "density".  This "density" has other names, one of which is the "tempic" field.  I researched this for a great deal of time - starting with the familiar A-field and B-field to find the work of Wilbert Smith and others.  Density implies a gradient or scalar - i.e. a single unit parameter like "temperature".  I used the word "parameter" on purpose.  In Smith's work, he explains that the universe is composed of 12 parameters in three fabrics of 4 parameters each.  7 parameters are required to study a particle and the other 5 are required to do something with the particle.  Density or the tempic field is the first parameter of the "field' fabric which is separate from the "space" fabric.
Anyway, you take this "density" and you "diverge" it.  This gives you an electric field - which has a vector and a scalar. Now that  you have an electric field, you make this loop on itself and you now have the "curl" of the "divergence" of the "density" - i.e. a magnetic field. This is dynamic so a constant change is required to maintain it.
Like I stated before - the field of this device must form as a vortex.
Some of you may notice a similarity with the mention of voltage and current on two copper rods in this vortex and similar statements by Tesla when he pulled 100 of amps from his coils or vaporized aluminum foil.
The more intuitive will notice that he said "copper" rods - no aluminum, no iron, etc.
So what if ths does not look like a ring!  Who said it has to?
The "kick" referred to is coupled to the time field - tapping the aether.
We might ask ourselves, what happened to the rate of time (entropy) within this field - this don't look like Kansas anymore...
Oh and last but not least - build it like he said and stop overthinking it.
EDIT: Time is the gradient of spin.
        -Frank Edwards
poynt99
At the nuts and bolts level, spherics' and SM's designs are quite different, yet I think we are being told that the fundamental operation is the same. I invite anyone to explain the differences and the similarities at the nuts and bolts level.
For all those that have this all figured out already, your input is appreciated.
I think in order to build either version we need to start examining the nuts and bolts of the device rather than "tempic" fields and the like.
