Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
seychelles
WILL A PHYSICS GRADUATE PLEASE TAKE A LOOK AT THIS AND GIVE THEIR SINCERE OPINION?
https://imgur.com/a/qnoUR4u
Paul-R
Quote from: seychelles on February 24, 2021, 11:20:19 PM
I find that image is impossible to read.
Magluvin
ok, putting the terminal block back on the 5 core setup now. Ive had the pdf for some time and the 5 core, but I wasnt sure what I was looking at or for at the time. Now that I have the thought that each primary affects only 1/5 of the secondary and those induced portions add in voltage, Im dying to go through the tests as in the speaker analogy. May need to see what goes on when only 1 primary is powered and then subsequent coils are powered, as with 1 primary there are 4 other cores affecting the sec. I may have to make a couple setups with just 2 cores, then 3 and so on to find how those other cores affect the sec. I worry that maybe with the 5 core that just powering 1 primary may lead to a very inefficient transfer that may increase in eff as I power more primaries. If so, then 5 may not be enough to break any barriers. Will see.
The most interesting thing I anticipate is the increase in sec voltage as I add in primaries vs what we get in an ordinary transformer where as we add more primary windings, the sec voltage would go lower. So power 1 primary and test the sec for voltage, and then add the other primaries 1 at a time and confirm what the pdf says of the sec voltage increase. Then power 1 primary and see what we can do with it as in a load. Like if it can drive a lite load at a particular level, and then put 2 primaries in series with the same input, where as I said before should produce the same voltage on the sec but will have reduced our input current by half, and see if it can still drive the same lite load the same or better or worse. If the same or better, this would be a good thing, because as we add primaries the input will reduce each time and see how far we can go with that.
Excited.
Mags
kolbacict
QuoteI find that image is impossible to read.
I can't read it either.
p.s.And if you do such thing? Just more rings.Maybe there will be something interesting?
