Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
0 Members and 16 Guests are viewing this topic.
sparks
Quote from: Grumpy on March 18, 2008, 12:44:58 AM
Look at all the little pathetic puppets.   Like little copper top batteries - so eager to please the Matrix and feed it's hunger.
How many before Spheric?  Hmm.  Sauron the Great - remember him?  Then there was that religious guy - I forget his name...  How many more before you wake up realize you are just his toys.  He throws little scraps of meat to the puppies in the pen, but never let's them play outside with the big dogs.
Look how the deciples crawl in the dust beneath the mesiah's feet, hoping that they will be blessed by a speckle of his spit.
He's been mind-fuking you for over 2 years now!  Wake up!
   I see your point Grumpy.  There are huge problems to be worked out with this design.  How do you shield your control pulses.  How do you route your output wiring so it doesn't screw up the vortex.  How do you shut it down in a hell of a hurry.  This may be an optimum configuration but I'd be content with a single spinor channel of potential energy from the aether into a capacitor at this point.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
Quote from: tao on March 18, 2008, 12:55:50 AM
There is too much collaborating evidence in support of what Spherics said being true though, Grumpy...
I for one will not just let this pass by unnoticed...
In the very least, I will do my research, like all people should, and they should conclude FOR THEMSELVES if they should believe what Spherics said or not...
8)
I never said Spherics was wrong, incorrect, or anything of the sort.  I just challenged him to "Prove it."  This should be simple enough for a messiah of his stature.
"Too much collaborating evidence in support of what Spherics said being true" - what evidence?
        -Frank Edwards
MACEDONIA CD
hi
@tao  hmm  way you dont see my pic simple i have send  5 days ago  ist here this my simple  pic   http://www.overunity.com/index.php?topic=4290.0
:D :D :D ;)
bolt
"The frequency should be a harmonic of the NMR of iron"  thats what we are told thats what we need to find out.
For practical purposes finding the frequency has just got a 1000 times easier. The ratio 3 to 1 is fixed there is no need to go looking for odd harmonic relationships of phi or Fibonacci etc to discover the 2nd and 3rd frequencies as there are only 2. This makes clocking MUCH easier on a shift counter and only the fundamental frequency now requires changing so long as the timing pulses remain locked sync the operation can be found by trial and error. Just sweep through till you get  a mushroom cloud :)
Bruce_TPU
Hello All,
Well, time to weigh in with my 2 cents worth.  I do not think that Speric is SM.  He either was his engineer or a member of this forum, under another name, at another time.  Who knows.  He did mention Bob Boyce's device, which he could not have known details about unless he had access or was mailed information...just a thought.  But his writing style is very unique and he speaks as someone who knows "for sure".
Regardless, what he says does sound informative and worth someones experimentation.  SM did mention that it would take "...a hundred years before anyone found the right frequencies."  Perhaps this is it?  It would be nice.
NMR of Iron:
Frequency relative to 1H = 100 (MHz)    3.237778
Source:  http://www.webelements.com/webelements/elements/text/Fe/nucl.html
As far as Jack Durban is concerned, his description of SM's intelectual capacity does NOT fit SM's writings.  You can not read SM and not realize the man is very intelligent and one who questioned everything.  SM did "have an engineer" but that does not diminish his reasoning capabilities, it simply proved that he needed others more qualified in a particular field to assist.  This also fits the SM of the writings.  Jack Durban also contradicts himself.  He never saw inside the TPU, yet he offered SM advice to "solve" the heating problem but SM wouldn't listen.  If Jack was not trusted with the "how it works" one has to wonder why?  I have no doubt he was at a demonstration, probably hired by some investor looking into the TPU.  Educated guess.   ;)  We will see with the interview.
Cheers,
Bruce
