Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
EMdevices
spherics, you're backing yourself into a corner.   Now your talking about actual rotors and Aspen, and you're also saying the toroidal coil is placed farther out.
Ok,   let's look at that,   the magnetic field vectors cut right across the x-secion of the toroid (a circle), and if you assume the field "rotates" about the z-axis,  you have a velocity in the PHI direction  (circumferentialy)
So which way is the induced voltage from such a scenario?    Well,  v x B gives you a vector in the THETA direction, or along a line,in the vertical plane, connecting the top and side coil, just about.   So you see, you don't get charges forced along the PHI direction, which is what's needed.   If you want to induce voltage and current with this "rotation"  then you need a different configuration for a "capturing" coil, not a toroid per say,  can you figure out how?
EM
P.S.  Grumpy, if you go up in voltage but keep the waveform the same, this means you need a broadband voltage amplifyer (since the square wave has lots of harmonics)   You want power as well, correct?  because my circuit will not add power, it just makes the voltage high.  If you do want power, then a push-pull amplifier (operating at 300V) will do the trick.
turbo
Quote from: aleks on March 27, 2008, 02:49:28 PM
Quote from: -[marco]- on March 27, 2008, 02:40:38 PM
Quote from: aleks on March 27, 2008, 02:32:39 PM
Your examples are not convincing
Why are you posting in the TPU area?
This was not an example.....
I bet you didn't even read it and i bet you don't even know where it comes from...
People like you will never understand.
No reason to go personal. I'm here to get ideas and share ideas. Beside that 'frequencies in coils' have nothing to do with voltages and amperages. I personally cannot justify the need of differentiation between Volts and Amps beside obvious schematic building tasks, where they solve the problem of energy in - energy out coordination. Instead of writing R=V/I you could write R=Eout/Ein.
Hey you tell me to give you some good arguments.
Then you tell me the examples are not not convincing.
Yet they came from the man who did it..
This makes me think that you think you know better then Steven and this i cannot believe.
I am sorry.
I wish people would read the literature.
Then they would just know why it is important in stead of just BLAH BLAH ing.
M.
Grumpy
        -Frank Edwards
Chad
at a certain point in the video you can hear the ocscillator give its tell tail wistle as its charging up...its very faint and obscured by background noise, you can hear around 4-5 separate charging wistle's from the oscillator!, ive known this for a long while and didnt think it was anything new untill i read spherics post about the caps being charged by an ocsillator, if this is of any use i can put you on to the exact point this happens in the video, if its not important no worrys just trying to help you guys along  :)
cheers
Chad.
Localjoe
So no one thinks the 79 cent camera flash boards will do the job??????????????????????????????????????????
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
