Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
kames
Quote from: aleks on March 30, 2008, 04:55:32 PM
Quote from: kames on March 30, 2008, 04:32:38 PM
...Attaining broad-band delay with wire is questionable, and should be considered a phase shift instead.
@aleks
Why not to go even a simpler way? Why not to measure the delay in distance between two pulses propagation?
You'll need kilometers of wire to have a measurable broad-band (group) delay in wire. 1kHz RF wave is 300 km long. If you want to cause a cancellation with two-way approach you'll need 150km of wire.
@aleks
Wrong.
I am talking about a very tiny delay. You still didn't get my point. My point is that a delay in a range of ms or mks is toooooo big. That is the point. I am talking about the delay that one cannot measure easily. That is why I said measuring in distance. And the delay has to be very stable and precise.
In addition, when an impulse is sent to the wire, there is no such a thing as broad-band. Check out the behavior of the inrush current before the magnetic field is established. Like a stand-alone impulse. It is a completely different story. Then read what SM said about the way his electrons are traveling.
Kames.
aleks
One note to everybody thinking in about "symmetry" aspect. Fe (iron) has cube lattice, no tetrahedrons and such here. So, original spherics' "close packing" of bubbles example is unapplicable here. On the other hand, iron (as other Face-centered cubic metals) does exhibit some icosahedron symmetry when it melts down (I've taken this info from a scientific paper). If Earth's core stays in liquid state the liquid iron may have some icosahedron symmetry.
aleks
Quote from: kames on March 30, 2008, 05:26:55 PM
Well, I leave this to you as I do not understand you, sorry.
eldarion
Quote from: aleks on March 30, 2008, 05:22:23 PM
Quote from: eldarion on March 30, 2008, 05:08:57 PM
Link: http://en.wikipedia.org/wiki/Earth%27s_field_NMR
Of special interest is that the NMR frequencies are now shifted down into the kilohertz audio range!
They should have performed this test with Fe. Unfortunately NMR measurement they did with H and C does not work with Fe. :) This is unrelated to SM TPU research.
Iron 57 has NMR frequency of 3.237778 relative to H1, so its frequency in the Earth's field should be around 6.475KHz.
I know iron 57 is quite rare, but Spherics did not specify which isotope of iron he was referring to, and iron 57 is the only isotope that exhibits NMR if I recall correctly.
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Localjoe
@Bruce
Remember when DFRO mention PHI in his post.
And take for instance my research into this feild showing that freq's that are multiplies of phi for instance .618 , 1, 1.618 , 3.236Ã,  are creative when hetrodyned with each other.Ã,  A lot becomes more clear. we were dam close well at least i know GK was going to test those freq for me .. I asked the poor guy a buncha timesÃ,  ;) ;DÃ,  Almost felt bothersome.. but i guess i was right on.Ã,   The other freq to mix should be in keeping with the exponet pattern PHI 1PHI 2 PHI
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã, Ã,  Joe
PS Quick refrence
1 X 1.618= 1
2 X 1.618= 3.236
3 X 1.618= 4.854
4 X 1.618= 6.472      6.475KHz ...pretty darn close
5 X 1.618= 8.09
Ect ectÃ,  ......
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
