Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
poynt99
@ Bruce,
You've just skirted around every point I brought up, and have muddled the facts even further.
btw, Spheric Audio Labs was "known" on this forum almost a year ago. Where are you getting your info from?
Rosphere
Quote from: aleks on March 30, 2008, 05:34:30 PM
One note to everybody thinking in about "symmetry" aspect. Fe (iron) has cube lattice, no tetrahedrons and such here. So, original spherics' "close packing" of bubbles example is inapplicable here. On the other hand, iron (as other Face-centered cubic metals) does exhibit some icosahedron symmetry when it melts down (I've taken this info from a scientific paper). If Earth's core stays in liquid state the liquid iron may have some icosahedron symmetry.
There is no relation between a tetrahedron and a cube.  ;)
http://mathcentral.uregina.ca/QQ/database/QQ.09.00/nishi1.html
Rosphere
Quote from: Rosphere on March 30, 2008, 12:18:51 AM...I believe that it is much more likely that the man made one mistake instead of twelve mistakes...
My apologies to the ladies.  I automatically assume spherics to be a man.
I have worked alongside many talented female engineers in my time.  It just seems like there are few to none in this 'biker bar' forum.
poynt99
Bruce_TPU
Quote from: Loner on March 30, 2008, 08:31:45 PM
Max Freq. for me is around 30 Mhz, but I hope to see something.......
@ Loner
Start off using the right frequency and it's harmonic, or any tests are going no where.  Sorry, but you need more MHz. 297 times more.
Bruce
