New HHO Cell Help 500ml 90sec
Started by rtsurfer, March 18, 2008, 09:18:29 PM
rtsurfer
Help me with this a little. It seems the cell produces high HHO in the middle and very low HHO on the outside. Here is an Image of the set up.
Now I am not sure why this happens and it is not an exact replica of the smacks booster but from what I see the positive around the middle 4 negative cells produce the high HHO.
I checked the flow and it is 500ml in about 90sec hot.
Here is the car view.
The plates are about 11" high sanded down SS plates using teflon bolts and PVC spacers at .08"
The HHO Cell is 4"PVC and stands 14" high.
ramset
RTS thanx for the Pix and post look here     www.panaceauniversity.org/Smack.pdf     read the new info added at bottom on how losses  effect your cell and what you can do     Chet
Thanks Grandma
readyakira
Did you try putting another plate on the out side of those 2 outer plates The only difference in the center to the outside is there is 2 neg plates on either side of the inner pos plate and as for the outside there is only 2 on one side and 1 on the other.  Just a thought....
rtsurfer
I am not sure about this but what I am seeing is the 2 neg plates are surrounded by positive plates. So I think my solution would be to move the left negative plate to the right side so these 2 neg. plates are together. Then add a positive plate to the outside right
So what I would have is:
Positive/Negative-Negative/ Positive/Negative-Negative/ Positive/Negative-Negative/Positive
But still I am not sure this will solve the issue. But I will try this on Saturday
nightlife
rtsurfer, are you saying that your electrolizer is producing high HHO in the middle of the negative plates and nothing between the middle positive and negative plates?
You drawing shows no production between those plates and based on what you have said. I would take one of the outer negative plates and place it nest to the other and add a positive plate and make the outer plates positive plates.
I am also wondering if you are using a pulse circuit to power your cell? If not, how are you doing with the temperature of the cell? How hot does it get? How many amps does it draw when it is cold and how many when it is at it's hottest?
Sorry about all the questions but I have been studying these a little bit and I would really like to know about these things I asked about concerning your cell.
