Most efficient method of electrolysis?
Started by BradleyH20, March 28, 2008, 07:05:21 PM
buzneg
very good post, I'm shocked by how much I'm still learning. But there is a mistake
"gasoline is mixed 14 ambient air to 1 part gas. hydroxy contains 2 3rds hydrogen and 1 3rd oxygen. you can see you clearly need more ambient air with this mix so no membrane is needed to seperate the hydroxy gas from the oxygen. "
The reason why so much ambient are is needed is because air is 80% Nitrogen, there's only 20% Oxygen in it. And fuel vapour is probably more H atom dense, and/or C atom dense, which requirs 2 O atoms to make CO2.
If additives dirty up the O as you say then the O may be made less useful, cause a percentage of it is probably part of some other ion, or molecule, therefore more air would be needed to replace that O.
vdubdipr
hey spewing.... at the risk of sounding stupid, which im willing to take.... how would i make un-pure dc? and what?  this is the first time ive heard the term un pure dc.  thanks in advance... i tried to look it up first and i couldnt find anything on this..
thats just what i think...
rockinricki
I too am chasing HHO as my prime energy sorce and quite new to it as well. I have found out many things in these past weeks and months that might help you out. First it is well to rememeber that this is a repressed,, misrepersented,, mistrusted and sometimes condemed technology by the governments and oil industry for good reason,,, yes thats right thier bottom line,,, its all about money. For the most part all of the other posts are accurate,, but I have found that differant reactors work slightly differant,, so ask youself what are you going to use it for,,, your car or truck,,, a cutting torch maybe,,, home heating or???? I have found that wire and screen work very well as there is a lot of surface area,,, not just on one side but all over the wire. I don't use lye or salt or anything else but H2O and avoid overheating or the runaway effect,,, I have the best results with well water but rain or snow water works well too although it takes time for the purer water to 'naturize' to the reactor but it dosen't grundge up as bad or as fast. The well water gets some grundge in it after a while but as the water heats up it dosen't seem to affect the production of gas to any great extent. I don't use any kind of pulse generater I found it is just extra hardware and it works very well without it. Regular 12vdc from a battery or charger works well for me.The production can be inhanced when under vacuum with more production and with somewhat less working amps (the reactor stays cooler). A small diafram pump works well as there are no sparks and runs cool to the touch. Put a header tank above the reactor or it will suck in the H2O or electorlite.  Where I live there are huge challenges to over come in the winter time for use in any car or truck, so my focus is on home heating and eletricity production and bulk production for storage and later use. I hope this helps you out best wishes RZ
ramset
ROCKIN I also am more interested in home heating  and like the idea of straight water  are you having any success ? THe Stiffler thread here has some HHo work with distilled water that should be  very  very interesting   also Bob Boyce has  a DC circuit as described above for running cars   HUGE HHO production!!!   PS I THINK STIFFLER IS GOING TO CHANGE EVERYTHING  as far as HHO is concerned  A MUST WATCH if your into hydrogen      Chet
Thanks Grandma
ramset
THIS MORNINGS NEWS  NYC  USA HOME HEATING OIL $4.11 a gallon  WHO is going to keep GRANDMA and GRANDPA warm this coming winter???  I know the oil heat in my house went off last week and I'm not turning it back  on  I have 6 months and I don't plan on Freezing [of course I haven't told the wife yet] Chet
Thanks Grandma
