The Forces, and Zero Point Energy.
Started by 0ne, April 02, 2008, 02:59:17 PM
Hope
This zero point may  be made or collected and perhaps that is what Ed Leedskalin's wheel did.  Notice the magnets all pointed outward which made the center of those magnets all point inward.  When he cause movement in the wheel he created a zero point in the center of the wheel which was collected within the iron mass below (old cast iron engine block).  So he could then draw from the sea of energy thru his "windings and air capacitors" to filter what he needed (which kind of charge) He was going to use the zero point to attract or nullify.  I know this is off topic but it is the overall key to the sea of energy if my thoughts on this are correct.  The nicest part of zero point is that it attracts ALL the energies of every type.  So Zero Point Energy is the wrong term, it should be called just The Zero Point or The Null perhaps.
What I mean by "it collects or attracts energies of every type" is all energies (positive or negative for instance..heat or cold..etc). Which make me think positive or negative charges are the same thing only our reference point is at a cental point between them so we see them as either positive or negative in reference to our charge or wavelength.
