welder
Started by shane436, April 03, 2008, 01:00:02 AM
shane436
Can these untis be used as power sources, with new inverter and pulse technology they should be somewhat efficient.
? im not a engineer..
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
http://www.millerwelds.com/products/tig/dynasty_200_series/
Thanks
Shane.
one
Quote from: shane436 on April 03, 2008, 01:00:02 AM
Thanks
Shane.
SHane
Maybe they  could be used  to test  ides ........ they are not  designed  to run constantly  .......
for example ........  the  350 model
Rated Output
    * 350 A at 34 VAC, 40% Duty Cycle
    * 300 A at 32 VAC, 60% Duty Cycle
If you  don't   know what they mean by duty cycle .......at  350 A   you can   run 40% of the time  without  overheating .
For most welding  this works  just fine ....... you  weld a bead .... reposition and weld another .   If  you  are welding  very long beads  you  will have to stop  every few minutes  or risk overheating
gary
pese
"duty cycle "mean
maximum 40 % from time welding ON.
Minimum 60% of the fully time no welding (stop).
Not possibel to run 100% steady over longer time at 300 or 350 amps.
