Free Energy Demon
Started by z.monkey, April 06, 2008, 08:29:41 AM
z.monkey
The Free Energy Demon lives in the Etheric Plane of Existance.
Transistors will never be able to solicit the Free Energy / Over Unity which we are all looking for.  I have had this idea nagging at me for a couple of weeks.  The energy we are looking for lives on another plane of existence.  To get it we have to open a door to that plane.  A spark, is that door way.  More precisely energy flowing through free space is that door way.  All of the classic Free Energy dudes either used spark gaps or tubes, never transistors.  Not just that they were not available, but they know that transistors don't have the kahunas to do this.  I am aware of some hardcore transistors that can switch  lot of power, but what they don't do is allow energy to travel through free space like a tube or a spark gap.  A spark, well self splanitory, makes a spark.  That is the doorway to let the Free Energy Demon into this plane of existence.  The vacuum tube has plates, between which energy flows, is allowing energy not only to flow through free space but rarefied free space, a vacuum.  A more economical to do this is a relay.  When the contacts open a energized circuit there is a spark that is created, the doorway for the Free Energy Demon.  This could probably also be done with a neon tube or a glass encapsulated precision spark gap.
The reason transistors don't work is the energy does not flow through free space, no spark no Free Energy Demon.  In a transistor the energy flows through matter.  Plus a lot of transistors today have a reversed biased freewheeling diode in them that shorts out the back EMF.  So that if you did get a decent amount of electromagnetic kickback your fancy silicon driver shorts it out and makes sure you will never see the Free Energy Demon.
I'll be modifying my current project to use a relay to switch the main coil and document the results.  I'm not saying that we cannot use transistors and microcontrollers as part of the design, like in wave shaping, and timing.  But the part of the circuit which generates the Free Energy / Over Unity has to be free of silicon switching.
Goodwill to All, for All is One...
Goodwill to All, for All is One!
NerzhDishual
Hi Z.Monkey,
You just could be right...
What about the Germanium Transistors and the Tunnel Diodes
(not yet fabricated but still available, I guess) ?
Do they have any Kahuna(s)?  (http://en.wikipedia.org/wiki/Kahuna)
Best
Nolite mittere margaritas ante porcos.
z.monkey
Howdy NerzhDishual,
Theoretically no, germanium is not free space.  I have been chasing the Free Energy Demon a long time.  He is a slippery little dude.  I'm going to try some experiments.  If this works like I think, I will be switching to vacuum tubes for my power drivers.  There is a neat little circuit in Nuts and Volts Magazine this month that describes a DC-DC converter to power the heater in a vacuum tube.
OK, Mo Later...
NerzhDishual
OK Z.Monkey,
I'm looking forward to seeing your results.
OT:
When I was about 16 (about 44 years ago :)) and a total newbie, I although
dared and managed to build a vacuum tubes amplifier for my guitar as I could
not afford a 'real' one. It was bungled but it had worked for a couple of years.
I just had to replace the EL84s (=6BQ5, I guess).
Best
z.monkey
Cool,
I still build guitar amplifiers.  My latest is a biamped synthesized stereo amplifier.  It's got tone control, distortion and SLAB (Sealed Lead Acid Battery) power, so it's portable.  I charge it up and go wherever to charm the ladies.  I have a bizillion iterations of FE/OU.  I could be driving a Bentley for what I have invested in Free Energy.  This time I'm gonna get that sucka...
OK, Mo later...
