The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Michelinho
@ Paul,
That's what I see as a way of controlling the unit. I just figured How I could control my version if ever need be.
The TPU should produce 2 central vortices on top and 2 at the bottom. and those distributes unevenly across the toroid.
The magnetic bubbles are asymmetric and counter rotating. They attract and repel at near encounter and start oscillating.
Your magnetic bubbles resonate and induce resonance in the toroid  and coils including the control coil. Could the effect negate your attempts at controlling by an input signal as it might induce more problem if what I visualized makes sense.
I see a control coil wound crooked as on staircases, you could induce a controlling pulse to your magnetic bubble with an ac input of variable frequency. This will also induce a shift between the inside of the bubble and the outside and probably not effect the control of the toroid. The magnetic bubbles bubble grow and fall while rotating and counter rotating. Washer action. That could boost output.
That means that instead of only a single coil for the control coil, I see many slanted ones of the same total potential.
Just a concept as you see this as a critical control. An over voltage could be used to brake the spin and an under voltage raise it. Self controlling. Brake applied before it starts running out of control. A bifilar coil would not interfere with the magnetic vortices but interesting under different winding style for tests.
Take care,
Michel
Sorry if this was mentioned after page 14.
Edit: and that opens up a lot of possibility for the source in ramping, phase delay, asymmetrical phase shift, etc...
Michelinho
Hi all,
A little more on the iron copper core with rust. Or is the knowledge only remembered in the Bagdad Battery, all the working stuff from before the last cataclysm. They knew the ingredients from wrecks but did not know how to use them. Just like us now. We must steps in some ancient shoes and what we call magic is reality. They replicated like us from rusted remnants to brand new parts. It did not work as intended. Maybe a Bagdad Battery with an rusted cathode or anode works wonders.
If my theory is right, the ferrous oxide crystal Latices must be able to convert at 100% efficiency the flow of electricity to a magnetic field that can produce that same flow in the copper coil. Can it do it? Supra Paramagnetic properties? What is that? New inquiries needed.
So a 5v 2 amps input would give a 5v 2 amps output. It is possible to replicate. The resonance of the tight cell filled with individual resonators or absorbers would prevent an overload (cloth, water and crystal latices). The coil structure self control.
Take care,
Michel
Michelinho
@ Paul,
I tried to visualize a perfect 4 coils toroid. It is my view of it, it does not imply it is right.
4 coils: 3 bifilar pickup coils and 1 bifilar control coil in small angle staircase arrangement. All coils are coiled in a tight formation as to maximize the magnetic field build up leaving no void between coils, those I see as drag lines. Deforms the magnetic bubble and induce HF resonance and unknowns. If the coils are not bifilar, a drag will deform the bubble to some extent as to collapse on itself.
The staircase control counter wound bi filar coil in a staircase arrangement. With a trick of polarity, your signal is continuous and you can accelerate the rate of spin by raising the potential difference and also slow it down by reversing polarity on those same control coils. Since the bubble spin rate has the least drag down effect from disturbances (regular coils), it will freely sing for you. That is harmony.
The basic power comes from the control coils which maximize the magnetic transfer for power to the core to build the vortices from the core but keep interferences with the magnetic bubble spin minimal. Variation to the spinning rate and power output is controlled by the power supply. Here too the rate of efficiency ask for a special magnifying core to get that 300% gain. That number 3 again.
It is just what I visualize with my views of what I have read, seen, tried or dream about.
Take care,
Michel
You get no external magnetic fields from a bifilar, so no drag. Or much less as there will be minute drag lines at the external level but it would be equalized around the coil and also minimal.
innovation_station
been haveing so much fun with this bedini motor this morn i thought i would check and see if it in fact was real power ....
on my chargeing battery ...
yep that is the real deal   cuz i got 1 hell of a zap far bigger than any previous zaps i have had  :o
so im gonna wind 2 more coils for my motor  also you will note with out movement my charge increases on my chargeing battery
hummmmm  is the sound it makes......
ist
it took me about 1 hout to build this unit not including the coil ;)
EMdevices
the spinning motor is discussed over here:    http://www.overunity.com/index.php/topic,3114.0.html  as slapper informed me (thank you)
GK,  he says in the video captions that he uses a magnetic field behind the carboard to cause it to spin (there's 8 videos so check the MORE INFO link for each one).   The tractor ring seems to keep it centered, but an interesting phenomena is the plastic cap "attracting" the spinning magnet.   Very interesting, but apparently not OU.
EM
