The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
forest
Why nobody tested obvious idea : how those kicks are modified by arrangement in space and by changing place. Measure it in normal envinronment and take it to the place with Earth magnetic anomaly. This should proof that Earth magnetic field is the source of those kicks.
Vortex1
Quotein the mean time, i wonder if anyone can figure out how this guy performed this trick.
http://www.youtube.com/watch?v=dTAJp5KyRIY&NR=1
I'll take this on:
He modified the power outlet strip by:
1. Cutting the internal wires from the outlet receptacles to the plug. Then he shorted the wires from the receptacles.
2. He replaced the neon with a LED and wired it with a small battery so that the plug and switch complete the circuit to the LED, but only when plugged into the shorted receptacles.
3. The vacuun cleaner has been rewired so that an extra plug is wired in series with the original (hidden) line cord.
4. The illusion of plugging the extra (fake) line cord into the receptacle merely completes the circuit to the vacuum.
SM may have used a similar illusion with the large lamps, where the wall receptacle was disconnected from the AC power and jumpered to merely completed a circuit through the lamps with hidden batteries and small inverter in the bases. His device output also had a short circuit which completed the current path into the lamps. A small oscillator in the device gave some voltage reading to the speaker terminals, but SM never actually measured the voltage at the output of the device, we all assumed it was the same as the speaker terminals.
....V
innovation_station
the kick as i see it
imagine a bubble  like our ionasphere  now make a bubble inside that bubble like a magnetic feild ok got that colapse that bubble what is the result?  the big bubble that this takes place inside will push upon the collapsed bubble and some engery will be expelled from the big bubble to make up the space of where the little bubble was ... and if this was air inside the bubble  and you had a valve like a 1 way valve upon the colapse of the bubble u could draw air from the big bubble as the pressure is higher in the big bubble
well that was a mess but i tryed
lol
ist
ill give her another go when i collect my thoughts....
poynt99
@Loner
i'm not moaning and i'm not tired of the question because in my mind it still has not been answered. so i'm glad you asked.
your first option is the best one; SM did say the kicks of themselves are OU. it is a small amount, but the idea is to create many thousand of them and have them combine (i assume in time) into one big current kick. then the goal is to have these big kicks (unipolar) happen in close enough spacing that for all intents and purposes, we measure DC with a meter. this is all SM, not me. i assume this "big kick" rate is the 5kHz or 6kHz rate that SM mentions.
is timing critical? imo based on the given clues, yes. is the device pulse-like both on input and output? imo based on the given clues, yes. SM said toa's capacitive discharge (pulse) is the key. is more than one frequency required to get many small kicks combining into one big one? from the clues, yes.
this should be review for most.
is rotation of field required in the process to make either the small kicks or the big kicks, OR is rotation of field a result of these processes going on? i don't know.
i'll just stop here. the bottom line is imo we're still at step 1; revealing the kick.
also Loner, if we go by what SM said, and ONLY by what SM said (which i highly recommend), then we are looking for a slight increase of current as the kick.
sparks
   I think to understand the kick we have to go to a third electrical phenomenon controlling field.  Gravity is an effect of this field.  This field is a flowing field of information.   It is a streaming flow of information as to the electrical density of reality.  Bascially imparting viscosity parameters to electrical phenomenon.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
