The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
sparks
  The torroidal configuration SM used is not necessary to get free energy from the phenomenon it  exploits.  It is poorly designed with no intrinsic safeguards.
Please review the below circuit.  This circuit is now incorporated in Tesla
Howitzers.  (replace the little battery circuit with a dc ionizing field).
  Now imagine taking the barrel of a gun and bending it into a ring firing a bullet that makes more gunpowder and detonates it every time it comes around.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
aleks
Quote from: rhombus24 on April 26, 2008, 06:28:13 PM
@aleks
I first started reading your posts and thought you had no knowlege as to electronics, then you said some things that only someone with actual knowledge in the field would know.  Then you screw it up again fighting with paul who has said some of the most important things I have ever heard.  You are wrong about the laser, it does work by causing electrons to shift levels, and no a mirror and light is not a true LASER it is a focused light source, I mean cmon dude you should really think about what you say but OK.
An electron DOES NOT have a missing proton that causes it to be negativly charged.  That only happens with atoms.  Just that really makes me think how much you know about anything to do with particle physics.
Do not start this again please, re-read what I've written. It is proton that lacks electron, not otherwise. About lasers, read here: http://en.wikipedia.org/wiki/Laser and check out its principal components. While 'stimulated emission' is important in real-world lasers, it is not the basis of laser work, and the only energy they receive is via external light or electricity source. Otherwise lasers would be perpetuum mobile devices (or COP>1 devices). So, it's still some form of reflection - this is what I was saying. In other words, it is a process of Q factor change in the photon energy probability space: the peak of probability increases while side-lobes of probability distribution function shrink. In signal processing this is usually achieved by some forms of feedback: be it via reflective surfaces or via some internal atomic feedback.
sparks
@Rhombus
   Hi!
       Go next door some time and ask your neuclear scientist guy  if electrons have mass.  Then ask him.   Why do neuclear power plants find it necessary to mess around with the neuclear mass when there is a guy on the internet that says you can convert some of the mass of the electron into energy.
      You can also tell him that radio frequency excitation of spent neuclear fuel rods can render them null within minutes instead of 20 or 30 thousand years.
Should rock his world a little. :D
    @alecks     have you taken the time to compress more knowlege of the kick phenomenon ? ;)
Think Legacy
Spread the Love
FatBird
Great schematic Mr Sparks.
Can you please label which winding is copper & which iron.
Can you also please label where the output is.
Thank you.
sparks
Green is iron wire   copper color is copper :)  output will be whatever you want to intercept a very fast changing magnetic field flux.  A regular iron core transformer should give you dual voltages.  Low voltage high amps out of the primary or high voltage low amps out of the secondary.  You can couple one of these outputs to a capacitor to store the power from the kicks and buidt a pulse generator later to initiate the pulse.  Core should be plastic with a small winding in there to saturate it magnetically.  You could also use a permanent magnet.
Think Legacy
Spread the Love
