Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
jeanna
@mthompson, thank you for those links.
@Gary.
QuoteWhat   are your thoughts about   this spaqe between the   main coil and the secondary ?
How much    space  did  you  leave  on   the coils  you  have secodarys on ?
gary
I thought I'd better bring this over here for the details.
I have made 4 coils with at least some form of secondary. The one I made closest to the patent description in terms of spool etc is giving the most dismal result.
I am not sure if it is because it cannot get moist very easily but even when I lift up the covering and spray water inside to the primary, the results are half of what they were before I added the secondary. I think this secondary has too few winds. It has 394 which is the whole red spool from RS, so I couldn't go higher but that is a filter (I think it is called that?) because the primary has about 360-400 turns of copper on it.
The other 2 that are in the ground have fewer winds than the primary but they don't seem to hurt the volts n amps as much. they are wrapped directly on the last covering of cloth that is over the primary.
The broken one is completely wild and crazy. It doesn't give ANY volts or amps on the primary and yet between One wire of the secondary and one wire of a second secondary that I wound around the iron wire 6 there is around 200 to 300 mvdc.
If I hook up a cap then the cap collects only 50mvdc. BUT still???? the other side of each wire is in the open air and the primary gives nothing.   I love this little coil.
The secondary is around 2 1/2 times the turns of the copper of the primary. I was trying to be neat, but the primary was so bumpy I couldn't so I scramble wound it.
Did you try to make any kind of secondary yet?
Did anybody else?
thank you,
jeanna
resonanceman
here is an interesting link
http://home.comcast.net/~onichelson/Fuelless.pdf
The last  half  of it  is about  the pancake   coil
gary
Pirate88179
@ Jeanna:
300 vdc?  Is this correct?  I am just checking because that would be something we all need to attempt to replicate.  I have not yet played with secondaries but, if I could get more juice, I would start playing today.  I have actually been pretty busy at work but I will get back into the swing here shortly.  I may have actually made enough money to buy some more wire.......look out... ha ha.
jeanna
oops!
thanks for keeping me honest.  ;D
I fixed it.
Good to hear youve got work.
more money more coils! yeay!
jeanna
Danner
Quote from: jeanna on April 28, 2008, 11:04:10 PM
Quote from: 1tesla01 on April 28, 2008, 10:11:19 PM
Guys (peizoelectric effect)=microphone
no kidding? wow. thanks for that, andy!
Here is the promissed shot of the verrrry big battery in front of the family: Just try to imagine how much wire is in this. It has something stacked on top, or something on top, anyway. Maybe it is a hollow pipe, maybe not?
jeanna
Hi Jeanna,
     Thanks for the picture in this post.  I think the stuff on top is part of a capacitor stack Bedini refers to.  Not sure if the big barrel like white part they are sitting on is part of that or not.. but the bottom left of the picture, does seem to be an earth cell.  It is kind of where the front left leg of the bigger thing is.
How do others interpret this picture?  What size would you guess the cell is?
Thanks,
Dan
