Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
Cap-Z-ro
Thanks Bill...if we're right about the water conditions possibly being a factor, which would seem logical to consider in a replication involving the properties of water, then it would almost have to be naturally mineralized spring water.
Distilled  water (steam) is dead water according what I have been reading from various completely independent health advocates.
Apparently water is energized by passing through the atmosphere and mineralized by passing through the ground.
Regards...
Pirate88179
Smokey:
Quote from Smokey: "so Bill, just to be clear on what you're saying here...(im going to call the ends of the core "top" and "bottom", because mine is oriented vertically, though NS said horizontally does not affect operation)i leave the bottom ends "open", and measure across the top wires, while its wet??"
I got the best readings from the copper on the top and the core on the other end.  This may or may not be the case for your coil so I would try all permutations.
jeanna
Quote from: protonmom on August 07, 2009, 08:18:04 PM
Jeanna...I think you misread what Smoky2 said.  He says he connected the neg AT THE BOTTOM to the pos AT THE TOP.
So, if that is the case then he did not leave the 10's alone.  Or, did I read that wrong?
You're right.
I was focusing on wondering why he even ended up at the bottom when the patent is very clearly drawn.
It probably doesn't matter with what he is doing anyway.
I made a really powerfull NS coil. Stephan even noticed and commented on the amps.
Within a day it was down by 75 percent.
This thing is a lousy galvanic battery.
If it were a galvanic battery to be reconned with, it would at least have zinc coating (which most of us did).
But, again, the ones I made with 'soft' iron were the best performers, even as lousy batteries.
Then with a secondary... I never had a scope.
I noticed for the first time how small the 2 generators were. Look at the pic of him standing in the middle of the 2. It probably depended on the application because there are many that are much larger, but it is really nice to see such a small one.
It is about the size (3 1/2") of the #3 which I have always got odd results from. It is the one in the youtube video you cannot see. called radiant joule thief1.
This is still a mystery, but I believe, one that is starting to crack.
And it is not a battery.
I do not know if it is a receiver or transmitter or both.
I wonder if it should be 3 feet above the ground too. In the family pic those 2 very large barrels are generators 3 feet above the ground. I may try to strap mine onto a piece of rebar.
The fun never ends!
thanks for pointing to my mistake,
jeanna
sm0ky2
i ended up at the bottom, because i made mine in the method described by Bill (even though he said to coil them back up to the other end...) i simply didnt have enough wire cut to perform that..
also, that would make it quadrafilar, not not bifilar....
i have since connected the 0-5 /1-6 without change to the operation. forgot to make a current measurement when i did this... will add later. but for now heres a photo.
i had to resoak the coil tonight, daylight sun dried it out and it stopped working.
sm0ky2
@ bill, i wil have to try tapping the core at a later time, mine ends are covered by the nylon stocking i insulated the core with.
but it seems to still work by connecting the ends of each wire together, so i have a copper loop and a steel loop, and it develops a potential beteen the two.
i'll cut away some of the covering from one end of the core and compare when i go back outside for more measurements.
