sm0ky2
i soaked my stubblefield and connected across steel wire on the bottom (-) and top copper wire (+)
leaving the other two leads open
it puts out 0.6v @ 8-12 ma
im now powering my JT circuit from this alone, as i have completely dissconnected it from the earth battery.
stubblefield and JT circuit are sitting on a glass table, in full operation as a stand-alone unit.
Success !!!!!
next step is to perfect the process of coiling stubblefields, and see if i can interlink several of them somehow...
jeanna
Quote from: sm0ky2 on August 07, 2009, 05:08:16 PM
Good job!
Yes, that is how he said to do it.
Those are the 5,6. The wires that you started with he called the 10 wires so even though they belong to te same piece of wire they are called the 10's
He said these must be let alone.
QuoteSuccess !!!!!
So excellent.
Quotenext step is to perfect the process of coiling stubblefields, and see if i can interlink several of them somehow...
And you can see from MY results what happens when you link them according to the picture of him talking on his wireless phone with one wire on the ground going to a grounded coil in opposite directions.
I have a pic.
jeanna
Cap-Z-ro
Could the chemicals in tap water have a negative effect on the cell, as opposed to naturally distilled and mineralized ground water ?
I recall that NS had wires coiled around the roots and branches of trees...could the 2 loose ends be connected there ?
Exciting to follow gang.
Regards...
Pirate88179
Cap:
Good point to raise but I don't think so.  Because the ground water run-off is not pure and distilled as was the rain water that fell.  Once it goes through earth's filters, it becomes pure again and I don't think his cells were buried that deep.
But, on the other hand, back then, way less pesticides and other ground surface pollutants and less acid rain so....maybe you are right that to replicate the rain he had back then, we might indeed need distilled water.
As I said...good point.
Bill
protonmom
Jeanna...I think you misread what Smoky2 said.  He says he connected the neg AT THE BOTTOM to the pos AT THE TOP.
>I soaked my stubblefield and connected across steel wire on the bottom (-) and top copper wire (+)
leaving the other two leads open <
Doesn't that mean he connected one of the 10's with one of the 5/6's?
So, if that is the case then he did not leave the 10's alone.  Or, did I read that wrong?
