Freezer
Quote from: Pirate88179 on May 26, 2008, 12:40:09 AM
Freezer also provided me with a schematic copied from Dr. Stiffler's site.  I hope the Doc does not mind if I post it here for us.  I strongly agree with Freezer that we should look into this.  This is mostly over my head as far as my understanding of electronics goes, but I am going to give it a try anyway.  This would light the LEDs indefinitely using only our earth ground.
Thanks again to Freezer and Dr. Stiffler.
Bill
To be clear I gave a link to his site and his image, but not copied and posted elsewhere as respecting his copyright issues.  I think? its ok to post here as others have done within his thread, but not to copy his stuff to other places so just be aware of that out of respect for Dr. Stiffler.  I'm still not totally clear on his copyright restrictions so we will see.  I just don't want anyone to get in any trouble with that, so be aware.
Quote from: storre on May 26, 2008, 09:16:49 AM
Seems easy to replicate this circuit. Is there some more detailed information on how to wind the coils etc?
His site should have the information, but make no mistake, is won't be easy by any standards, hence no one on this site seemed to have replicated it.  ;)
@Bill I hope this circuit can be realized if it is indeed what it seems to be.  Even a little power like that could make a huge dent in the scientific world, if people could readily duplicate it.
storre
Quote from: Freezer on May 26, 2008, 10:00:46 AM
What is the link to his site?
Pirate88179
Below is the link to Dr. Stiffler's site.  Freezer is correct, he sent me a link and did not copy and paste like I did.  I am sorry if I did not make that clear.  I hope Dr. Stiffler does not mind.  He looks in on our topic from time to time and if he objects, I will modify the post and just put the link there.
The coils can be purchased and are very cheap.  They are the same ones used in am radio's as the antenna.  I found a source but I am still checking to make sure the coils and cores have similar values to the ones used by Dr. Stiffler.
http://stifflerscientific.com/  Dr. Stifler's site for his SEC experiments.
The link below may be a source for the litz coils and cores:
https://www.scitoyscatalog.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=SC&Category_Code=R
This could be very interesting if it works.  There is a lot to this and it will not be easy.  I am still reading on the Dr.'s site to get caught up.
Bill
DrStiffler
Quote from: Pirate88179 on May 26, 2008, 12:36:44 PM
Bill
@Bill & All
This circuit was withdrawn from the public (remains on my web site) because of extreme static I received when I tried to present it. It was replaced by a powered circuit, because that was received as possible. The circuit works, but the ground shown is not what you all consider to be ground (not that earthy dirt you plant your cells in). This ground is a component of the ground in a home or business electrical wiring system. In the US a common home or office has a Hot, a Neutral and a Ground. The ground is for added safety, yet it contains signal (induced and leakage currents). These currents are used to excite an AV plug in a highly tuned pair of coils. One coil excites the other which provided the starter coil (if you will) with positive feedback which allows the building of the oscillation. This is the basis of this circuit and is not something the faint of heart should try even though I have circuits running over 100 LED's in the lab.
What is important to understand is that it depends on a minimal signal input from the ground. If you drive a rod into mother earth and connect this circuit it will not work. This is a false alarm for you work.
All things are possible but some are impractical.
Pirate88179
Forget my source for the litz coils.  Freezer pointed out that they do not have any specs on them.  He gave me a link
I will post here to where Dr. Stiffler was getting them.  If anyone is going to attempt this also, remember it is important to use exact components as published by Dr. Stiffler.
Litz coils:http://cgi.ebay.com/Ferrite-Loopstick-Antenna-Coil-Crystal-Radio-680uh_W0QQitemZ150089628196QQihZ005QQcategoryZ7275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Bill
