Stanley Meyers Coil USes Volts not Amps to create HHO
Started by rtsurfer, April 10, 2008, 06:52:06 AM
rtsurfer
I have been watching a great video of Stan talking about his design. His design uses little to no amps to produce HHO from water. He uses a coil that multiplies the voltages and takes the amps out. So my thoughts when looking at the design is a HEI coil out of a car. And that is attached to a PWM. Here is a drawing
Has anyone ever tried this? Is it possible.
You may put in a capacitor between the PWM and coil to help the coil recoup as it uses the energy.
Any thoughts.
z.monkey
Hey RTsurfer,
That sounds feasible to me.  I have a board that you can use to modulate the coil.  Check out this link.  There is a PDF file which is the schematic.
http://www.overunity.com/index.php/topic,4293.0.html
And another thread discusses using this board to control the production of HHO.
http://www.overunity.com/index.php/topic,4424.0.html
So does the RT stand for R/T like Hemi powered?
I want a Big V8 so bad, I just don't want to pay the fuel cost.  If we could get a reliable HHO system working then I would not need to worry about fuel cost.
It's a fuelish endeavor...
OK, Mo Later...
Goodwill to All, for All is One!
Jonny Q
Hey rtsurfer
I imagine it could be done, my biggest question is whats the temprature gonna be like on a cell that your pumping that much voltage into? If it sky rockets you'd have to find a way to bring it down and stablize it. via using bigger gauge wiring thicker plates or electrodes, adjusting voltage etc. just some thoughts.
rtsurfer
Stan mentioned that by using coils to remove the amps in his system and multiplying the voltage he creates a system that produces very little heat. From what I can see he has a coil on both sides.  Connected in series. Once the first cell uses the voltage and drops what is left on the negative he then picks up from there another coil (positive side) and the replicates the coil from the center to another cell. SO he uses on coil infront of the first cell and between the first and second cell.
Thereby using the left over energy from the first cell and multiplying that voltage to power the second cell. This is connected in series.
He used 4 cells to move his VW  (1600cc ICE)
This video goes into more depth. And it is way more then I understand at the moment.http://video.google.com/videoplay?docid=-8355517779975365309&q=stanley+meyers+duration:long&total=17&start=0&num=10&so=0&type=search&plindex=0
But from what I can gather there is very little heat produced from using voltage instead of amps.
And he uses plain water no baking soda ,potassium, sodium or salt
Feynman
According to Jon / Free Energy Group, your are gonna have to send pulsed DC into that auto ignition coil in order to get your high voltage out.  Generally you can do this with a 555 timer driving a power transistor.
