HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
mudwump
Alas, it is not good practice to dismiss an observation so fast. It is not too thin to do many things. I just find it a little odd to laminate two pieces when using one thicker piece would have sufficed.
aleks
Quote from: mudwump on April 20, 2008, 12:13:51 PM
Maybe there are two iron rings hidden inbetween two wooden halves and then laminated? Any way, dielectric substances can hold a lot of charge on their surfaces: this is what can be also important. Especially dielectrics composed of layers (or two halves as in this example).
poynt99
think what is probable
those rings are 1/4" thick, max, and could be as thin as 3/16"
if one tries to router out a channel for some wire, the thing is going to break, or at the very best become quite weak and prone to breaking and flexing.
so with an apparent lamination, it looks like thin plywood. it's not metal, and there's probably no wires hidden within. let's use the razor and move forward
Localjoe
@Jdurban
Thanks for the quick reply.   In pat 381,970   Tesla says this
In the present application
my object is to describe the best and
most convenient manner of-which I am at presntly aware of carrying out the intention as applied
to a system of electrical distribution;
but one skilled i the art will readily understand
from the description by the modifications
proposed in said applications
, wherein the form of both the generator and converter
in the present case may be modified.
Said application numbers are Serial Nos. 252,132 and 256,561
But there pat numbers are 381,968  382,279
Sparks made a comment in another thread that seemed impt to this so i want to repeat it.
he said ""Steel in the core if you want to make an induction generator yes.  Steel outside the core if you want to make a dynamo. "  We were dicussing the uses of steel or not.
After reviewing all the said modifiications tesla proposes throughout the first two patents then implmenting them on the 381,970 it becomes clear that these two devices could be combined into one.  The trick is rotating them properly.  The coils have to be a diametriclly oposite positions and run in series. Some of the thicker induced coils wound upon the copper may be shunted in the same ciruct . "Some in series, some in parallel".. similar to an old sm quote we had
"It results from this
that the different electrical phases in the generator
are attended by corresponding magnetic
changes in the converter; or, in other
words, that as the generator-coils revolve the
points of greatest magnetic intensity in the
converter will be progressively shifted or
whirled around"
He also notes many ways to build the two elements the feild coils and armature and different configs they can arranged in. The goal he wanted to convey in my mind was a version of the motor and generator combined into one device with no moving parts and no mechanical limitations.  This may not resemble the otpu but it sure does the others.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
BEP
1/4 inch plywood - agreed. Then it measures between 3/16 anf 1/4 inch thick. That should allow fairly accurate scaling for other parts. Solid wood sheets that thick were no more available then than now.
If my current train of thought is correct then one of the three conductors of the twin-lead windings is a portion of the collector. That would be the one in-between bifilar control coil conductors.
@Wattsup
Wire spools of that size then were also made completely of plastic. A few had plastic ends and a rolled metal core but they were obvious. This one is obvious to me as the all plastic variety. The 'see-through hole' you pointed out would be the normal one - part of the spool manufacture. There is another hole closer to center that should not be there. ref: other pic uploads on this thread. There is no downloading huge files from my connection.
