HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MeggerMan
@Sparks,
Neutrino bomb - I think you mean a neutron bomb, neutrinos pass through everything and I think they are harmless at least at low levels.
AM radios, thats old hat, I built one when I was about 11 - big deal.
We have to explore the videos as there are several people that can confirm that they worked and therefore it gives us a set of parameters to work within for the most basic model.
@All
Going back to Spherics idea of the tetrahedron, I think it needs to be inverted so the vortex cone is facing into the upper atmosphere.
As I understand it, it also implies that top coil is pinching the vortex and forcing the twisting field through and around the collector coil.
Rob
sparks
    @meggarman
         When you built your am radio did you ever understand where the power came from that came in on the antennae that you resonate..  I didn't say anything about a neutrino bomb.  What do you think the magnetic field inside the tpu is spinning up?  Do you have a clue as to what magnetic flux is?
Think Legacy
Spread the Love
BEP
@sparks,
I appreciate your nudge to what you may think is right. Built my first radio in early grade school. Wiped out all radio/TV signals within miles at 12. I even had the enjoyment of destroying electronic ignition systems on running cars within a couple of blocks back in the 80's.
No, fields don't rotate and magnetic flux won't either.
I think you'll find the so-called tetrahedral method will actually build a spherical field (no pun intended).
I'm not after how to make power - I'm after how to control it because loading things like this just makes it stronger.
