How much amperes are needed for a newman motor?
Started by Magnethos, April 15, 2008, 04:26:10 PM
Magnethos
Hi, I read that newman motor runs on voltage, not on current. I want to know how amperes or miliamps are needed to run a newman motor.
Careica
Quote from: Magnethos on April 15, 2008, 04:26:10 PM
Ofcorse ampers/current are needet to run newman motor. Because: Power = Watts. Watts = Volts x Amps. Whitout amps, newman motor will not get power to spin in. And ofcourse it need ampers, but very small amounts like 10-20mA. But less amps is better.
Michelinho
The answer to that is: not one motor is the same.
The Newman Motor use high voltage and low current for efficiency. The coil does not get hot but get's a few tenth of degree colder when running. For a small coil to use low current, you have to use very small size wire.
Here is part of a wire chart:
AWG    Dia-mils  TPI       Dia-mm    Circ-mils Ohms/Kft  Ft/Ohm Ft/Lb     Ohms/Lb  Lb/Kft    *Amps     MaxAmps
30         10.025    99.750    0.2546    100.50    103.19    9.6906    3287.1    339.18    0.3042    0.1340    0.2010
31         8.9276    112.01    0.2268    79.702    130.12    7.6850    4145.0    539.32    0.2413    0.1063    0.1594
32         7.9503    125.78    0.2019    63.207    164.08    6.0945    5226.7    857.55    0.1913    0.0843    0.1264
33         7.0799    141.24    0.1798    50.125    206.90    4.8332    6590.8    1363.6    0.1517    0.0668    0.1003
34         6.3048    158.61    0.1601    39.751    260.90    3.8329    8310.8    2168.1    0.1203    0.0530    0.0795
35         5.6146    178.11    0.1426    31.524    328.99    3.0396     10480    3447.5    0.0954    0.0420    0.0630
36         5.0000    200.00    0.1270    25.000    414.85    2.4105     13215    5481.7    0.0757    0.0333    0.0500
37         4.4526    224.59    0.1131    19.826    523.11    1.9116     16663    8716.2    0.0600    0.0264    0.0397
38         3.9652    252.20    0.1007    15.723    659.63    1.5160     21012     13859    0.0476    0.0210    0.0314
39         3.5311    283.20    0.0897    12.469    831.78    1.2022     26496     22037    0.0377    0.0166    0.0249
Using this chart you can tailor the coil's resistance.
AWG 30 coil: The TPI section is the turn per inch section and that says for one inch of coil winding you will have 99.750 turns neatly placed on the first row of your coil. So for a nice coil 2" x 1/4", you would need 199 turns for the 2" winding stacked 99.750/4=25 rows high for the 1/4" height.  199 turns X 25= 4,975 turns per coil. That is a big small coil as you need 2 of those for the split coil model of 512 ohm.  A 4" coil will be about 12" around and use 4,975 feet of magnet wire in IDEAL CONDITIONS.  An oval coil will save you wire and it is more efficient. So the Newman Motor would have 9,950 feet of magnet wire with a 512 ohm resistance.
In normal life, the coil will be fatter because it is hard to wind a small wire in perfect rows. The coil will end up 2" X 1/2" or a little less and the number of turns lower for the added size of each row.
Grab your pen out and have fun designing your first Newman Motor from scratch.  ;D
Take care,
Michel
khabe
More amperes?
Little bid sad to look when poorly and folly built bases for experiments. Very seldom saw using of back iron ...
Hereby Lehner LMT 3060 brushless motor, 12 turns, Max power 8 kW, Rotor diameter 30mm, rotor lenght 60mm,
Yes - - -  3 phase BLDC but you can see 6 output wires ( delta connected right now) - take just ends of phase A (or B or C) and you have well made
base for Newman experiments. You can use two phases A and B for example, If you like to have "two coils" ...
There is extreme powerful two pole rotor, There is laminated back iron around the "coils" - provides more perfectly finished magnetic circuit. (of course rotating outer back iron ise better  but ...)
You?ll have shaft where to install all the rest you need  like collector .... what ever - of course it need to be adequate built very large for 100...200 and more ampers ;-) Efficient of this motor when commnly used with adequate bldc controller is at least 90%  But OK - your choice is to use Newman Style - Hopefully you will get "huge back impulse" as well  and huge batteries will be recharged ;-)
Lot of existing air-core (air gap) motors, different brands you can use - very many motors what are correctly made you can use for experiments, radial gap, Axial gap ...huge diameter, smaller ones ...
Commonly much more turns than this Lehner extreme powerful motor has. I think that even brush motors could be used (then moving wound coil) the only thing - m,otor must to be air core (air gap) not iron core (armature). Jus a little bid rebuildings, reconnecting wires ...  I have tens of such kind servo motors, different sizes ... mostly cheap bought from ebay.
Regards,
khabe
Myself Im not believer of Newmans wonder machines, because I do not myself - just chummy advices how to get well built base for Newman experiments
Michelinho
 Hi khabe,
You got yourself some very nice motors that can be used for many projects. Another cheaper option is converting a ceiling fan to alternator. Just have to remove the stator ring and install magnets around. Stacking magnets help boost efficiency as used in the Romag magnet setup as it amplifies the magnetic flux.
Have fun with your researches,
Michel
