inComplete information on working SM style device
Started by EMdevices, April 24, 2008, 11:42:23 AM
EMdevices
slapper
Dang-it EMdevices: That is making sense. Now I'm going to be late to work. :)
So we need to take the voltage across the + and - and adjust it to a certain point to where a device across V and W will breakdown. But that breakdown is only temporary and opens itself up again only to go into breakdown mode again, i.e.; self oscillation.
So at that point do you feel the core material can be iron wire which will have a voltage we can tap into?
Thanks and take care.
nap
now I got to go to work :(
we are not alone :)
aleks
EMdevices, cool. Looking like open TPU of SM :)
BTW, do not forget that square waves or saw-tooth impulse trains are actually AC at their fundamental frequency, just with a lot of harmonics. Actually, I wonder how this coil will transform just a square wave signal.
On the other hand, I can hardly imagine a real-world circuit. They have a ring of 1-2-3-4 coils that does not have "ins" and "outs" yet W and V should be somehow connected to external load or supply, or just to P and N points (kind of local short-circuiting). Should the DC current be collected by winding a third coil on top of all coils, or near 1-2-3-4 coils in bifilar fashion? Still connections W-V vs P-N should be switched somehow - probably by using reed switch that depends on the AC polarity of I-II-III-IV coils. This makes it possible to consider W+P | V+N and W+N | V+P connection states, depending on the AC polarity. Here we have a rotating magnetic field again, and a bit of voltage spikes due to reed switch action. Hall effect switch can be also utilized it seems.
Frederic2k1
You should change the topic...  ;D
Amazing!
The similarity between this and the openTPU of SM is really awesome...
8)
