"New" SMOT idea?
Started by tmpcbtc, April 25, 2008, 01:50:31 AM
tmpcbtc
Ok, so I was reading about the SMOT and I just want to see confirmation on one idea that has not been answered from what I have read.
If you can see the picture of the two smots I drew in MS paint, it seems really simple to get a ball back to the start of the first smot by having two side-by-side.
If the ball can truly be lifted upward as many people seem to attest, and if you could theortically lift a ball up to say 5 inches from a 1 inch starting point, enough to drop free from any magnetic pull, and then run down a curved ramp to the start of a second Smot, with enough speed to get into the channel of the second, go up that ramp and repeat with the first, it would be a closed loop. Right?
Some "skeptics" have said the Smot is perfectly legitimate, in that it can raise a ball up a ramp. If so, why have people not attempted the method I have drawn instead of putting them sequentially?
utilitarian
Quote from: tmpcbtc on April 25, 2008, 01:50:31 AM
You want to raise the ball 5 inches?  I have not seen that, but good luck.
AbbaRue
The age old problem with the smot;
To keep the ball rolling up the hill the magnetic pull has to keep increasing as you go along.
Once you get to the end of the smot the pull of the magnet is very strong and no one has found a way
to escape the pull of the last magnet. It always pulls the ball back again so it can't drop to the next smot.
This goes for the other similar devices like magnetic wheels.
You will always notice the driving magnetic field is pulled away as you get to the end.
If one could discover a magnetic shield which could fall in place just as the ball reaches the last magnet.
Always keep in mind the thought of a magnetic bearing, which is almost frictionless.
Spin something in a magnetic bearing and it will spin for hours without stopping.
Many of these magnetic motors are just fancy examples of one, hidden in all the technology.
This is what deceives people into thinking they found a new source of energy.
The proof of a true magnetic power source will be to have the device speed up as it runs, and not just keep running.
Find a magnetic shield so the ball will drop to the next smot and you have found the answer.
Koen1
Do you really think people have not tried that?
I have, in any case.
The problem I experienced was that:
-  either you have to pull the ball back from the
ramp entry point a little, so that you feel the magnetic attraction pulling on the
ball, and then when you let it go it will roll up the ramp and "shoot" off the other end,
and this only works when using that "magnetic spring effect" so you need to input
energy by pulling the ball back, which is obviously not possible in a continuously
rolling version
- or you place the ball in front of the track entry point and let it go, where again you
can feel the pull on the ball, but now without the added "spring effect" the ball gets stuck
at the end of the track, does not roll off it, simply because the magnetic attraction at that
point is strongest of any place on the entire track.
A sequential version, which is actually not at all different from the setup you proposed,
must do without the actual manual backpull, and without the manual insertion of the
ball in the magnetic field; instead, it must either somehow produce this backpull which
no version I have ever seen actually does, so the entire "spring effect" is not applicable
in any such sequential version (that I have seen designs of), or it must overcome the
magnetic attraction at the high end of the ramp, which is quite difficult as that is the
very point where the magnetic field is strongest; adding magnets to pull the ball away
from that spot messes up the nice increasing flux zones that make the ball roll up
the ramp in the first place, so that doesn't work...
Perhaps with some very ingenious alterations and magnet placement and shielding
it could be possible to make the ball drop from the high point, and as soon as that
is done any number of ramps can be added in sequence to complete the loop.
But that is more difficult than it would seem... ;)
tmpcbtc
I am certain that every possible method has been attempted and I'm sure they have all failed, but...
smot link
This ^ clearly shows the ball going through two angled SMOTs in a straight line. If the ball can go up a ramp, of any degree, and then fall off, then what I described should be possible.
I also read somewhere that some company made a 2 footer, which would make the end of the ramp considerably higher than the short ones depicted in the link above.
I mean, in any SMOT video you see, the ball clearly exits the end of the channel.
