elemental rod
Started by slayer007, April 25, 2008, 01:16:11 PM
Koen1
Well if you look at the top of this page, you'll see a post by JustRite
in which he says he knows the inventor...
... and he doesn't sound very Japanese to me. ;)
But indeed it could be a Japanese inventor...
Although it seems unlikely to me that the MIB would
allow Justrite to meet with the inventor and test the rods
before they went and suppressed it in Japan even...
I would think that the Japanese branch of the MIB would have
picked up on it long before news ever reaching the US...
...but maybe that's just me... ;)
Bruce_TPU
Quote from: Grumpy on June 18, 2008, 11:53:04 PM
To post a "how to" pdf would be a waste of time.  Half of the people that ever see it would find a reason to discredit it before they ever build it.  All but one of the other half wouldn't even try and just file it away in case their insatiable urge for drama needs another episode.  So, one in a million would actually benefit from you putting your ass on the line, and you become a martyr.
(snip)
Hmm - carbon rod with a polarized coating might do the trick...
Hello All,
Grumpy said it well.  Someone has already posted how something works and no one believes it, and everyone ignores it and goes on their merry old experimenting ways.  It is downright sad.  And then the moans come.... It is a Greek tragedy.  Funny if not so sad.
@ Grumpy
I definatly agree, that both rods could be carbon.  There is a thread here at OU about some interesting experiments with carbon rods.  I'm sure you also have seen it.  (Those reading can look it up.  Search "carbon".)  Interesting stuff.
Cheers,
Bruce
amigo
I totally agree that posting a how-to document to a bunch of orthodox scientists or alternative energy researchers would be an utter waste of time. These are the people who do not wish to believe, know, or see it happen because they live for the thrill. The first ones for the skepticism and debunking, and the later ones for the urban legend stories.
With the orthodox scientists, they obviously do not want anything changed because they will lose cushy positions of tenure and millions (billions) of dollars in grants for the research that leads nowhere. Meanwhile, the alt. energy researchers mere existence is based on the search, never ending continuous quest, where goal is always at a hand's reach away but never graspable. They do not want the quest to end for that would be the end of them and the end of the thrill.
So, the plans need to be disseminated to normal people, the iPod carrying, SMS texting teens and all of the minions of the corporate world using laptops. When they do not need to recharge their devices EVER again *they* will let everyone know, and this kind of viral marketing cannot be stopped. You will see it on Facebook, YouTube, and elsewhere and the "damage" will be done regardless of MiBs coming to get you or not...it would be irrelevant at that point.
Grumpy
The inventor of the rods said 73 elements in one and 74 in the other.
There are not 73 or 74 metallic elements...only 40+ and only 100+ elements total.
I suggested carbon with some additive and quartz and some unknown polarizing coating - why?
Radiant energy is much like light.  More like light than electricity.
Smoke on that for a while...
        -Frank Edwards
pauldude000
@grumpy
You know, this just reminded me of that Huchtison dude, and his batteries. You may be familiar, I do not know.
What gets me is his descriptions. You could tell that anything he actually came across, was sheer accident, as he had less than a clue about pretty much everything he worked with. (I have watched and seen much from him.) However, his technique is BOUND to get some results.....
You mess around carelessly enough, long enough, with enough power, with no knowledge of what to do right OR wrong, and you will stumble over something. ;D (Or it will stumble over you.)
Anyway, I remember a video of him making an "earth battery", or some such. If I remember correctly, his approach was to look for various rocks, smash them with a hammer, cram them in a can with a rod in the center, bake them in an oven, then charge them with high voltage.
I remember the rocks he picked up were quartzine from the look of them in the video. (I used to be a rockhound as a kid.)
If the rod were carbon, you would have a carbon rod coated (surrounded by) with pseudo quartz (quartz, with other various minerals).
I wonder.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
