Human motion energy converter
Started by tmpcbtc, April 26, 2008, 02:05:01 PM
tmpcbtc
Ok,
If anyone can enlighten me...
You take an extremely efficient magnet wheel, that spins x amount of times from one push.
You connect that to coils to produce electricity.
How many watts could you get out of this?
How many watts does it take to power a house?
If you could just "sit and spin" the wheel (or wheels) once and a while, wouldn't that produce excess power? Not overunity, just sufficiently amplifying the human motion input.
Right?
Creativity
actually electricity generators we use r just a wheel and some coils and we use the energy to rotate it.In that case u have no excess energy... household takes like 10-20kWh per day.
Blues it through your outstanding life,leaving more than just footsteps behind (1999 B-stok by me).
By being intensively responsive to what others say,i do run a risk: I open myself up to the opinions of others.i will,at times, have a great understanding for their opinion.Sometimes,i will even change my own opinion because i realize that the other person is right.This "risk" i do not run if i am unresponsive to what others say.
gyulasun
Quote from: tmpcbtc on April 26, 2008, 02:05:01 PM
Ok,
Hi,
It is ok you have a easily turning magnet wheel, turning for minutes from one push BUT the moment you approach this wheel with coils and use the induced electricity for feeding a load,  your wheel starts slowing down very soon and stops. Of course you may push it again and again...
Right?
Have a look this link, it may answer your questions:
http://www.windstreampower.com/
http://www.windstreampower.com/Human_Power_Generator_Series.php
http://www.windstreampower.com/Human_Power_Generator.php
http://www.treehugger.com/files/2006/03/pedal_powered_p.php
http://www.econvergence.net/electrofaqs.htm
Good reading!
Gyula
tmpcbtc
Quote from: Creativity on April 29, 2008, 08:44:29 AM
Thank you for this little tidbit, I like getting numbers for this stuff.
Do you know if there are batteries capable of supplying 10-20kWh per day? Such as the deep cycle batteries used with solar power?
Creativity
hey ,
for best numbers for your home case just check your electricity meter :) write down the numbers and after 7 days write it down again,then divide the difference by 7 and u get an approximation of what r u using per day.
about the batteries...probably guys from solar systems found already reliable batteries so google around (i have little idea about this).With car batteries u should be carefull not to drain them too much (never go with voltage lover than 10.5 V) so kind of circuit would have to take care of that.Typical car battery is capable of 65 Ah
so it takes 65 h to drain one with 1A current(so 12W load).Average of 10kW/h in 24 h gives like 450 W/h.One 12V car battery would run such a load for 37 min.
But of course u have peek hours (dinner cooking,dish washing) and those machines use as much as 2-8 kW.In off peek (at night) u use very little electricity. It is also better for battery to be discharged by steady low current,so battery bank would be the best solution.
