David Bowling's Continuous Charging Device
Started by sterlinga, April 30, 2008, 10:56:29 PM
Dbowling
If you're interested enough in this thread, go check out what we are doing at:
http://www.energeticforum.com/renewable-energy/10610-3-battery-generating-system-99.html
We have come up with a test I HOPE will satisfy everyone, and will be conducting it as soon as the parts get here. Meanwhile, we are DANG close to having solved all our issues and have a stable setup anyone can build.
Dave
Hoppy
Quote from: Dbowling on October 19, 2013, 12:05:55 PM
Dave
David,
Please post a diagram on this thread showing the configuration of batteries and motors etc that you are currently using, together with notes on battery conditions necessary to fulfill requirements for a stable setup. I'm sure a few of us would like to come on board with experimentation.
Farmhand
I was wondering, with all due respect. To those who claim something special is going on and there is a more energy out than energy in situation or effect taking place.
!) Exactly how can it be that more energy can come out of a device than energy that goes into a device, including all the energy contained in the batteries right from the point of construction and including the energy contained within the matter of the device itself, and the initial energy required to first charge the batteries ?
2) In other words how can anyone expect to get more energy out of a device over an extended period than work that was done to create the materials and construct all the parts of the device in the first place and all the energy contained within the materials the device is actually made from ?
The way I see it it is completely impossible for any system to output more energy then is input into said system at all previous stages of construction of the materials and device.
ie. The energy used to initially charge all the batteries and the energy locked up in all of the actual matter the entire device is constructed from.
Logic and common sense says that for it to come out it must first go in, unless something is created from nothing.
In other words actual OU is impossible by definition. Energy cannot be created from nothing, it is not possible to create any actual thing or work from nothing. To me that is pure logic.
Therefore logic tells us that any energy coming out of any device simply has to have gone into the device at some point previously, before it is possible for it to come out.
So I ask can anyone explain exactly how they expect a device to output more energy than is input into the device and it's components previously ?
Dbowling
Farmhand,
I see you on various threads here and at EF, carefully explaining why OU is not possible. Don't you ever get tired of being so negative all the time? Why it's almost as if someone was PAYING you to be so negative. LOL. But you have outdone yourself this time. If my device doesn't put out as much energy as it took to manufacture the wire and steel and the batteries it was made from it is not a real free energy device?? You have truly lost it! I can't wait to copy and paste what you posted here onto the thread at EF. They are gonna laugh until it hurts.
Either you BELIEVE OU is possible, or you don't. Having seen it for myself on many, many occasions, I have no trouble AT ALL believing it is possible. Now that doesn't mean I buy in to 99.9 percent of the nonsense that is on these forums, because I don't. Unless I can see it with my own eyes and touch it with my own two hands, you would have a heck of a time convincing me it is for real. Now as to your question, how can you get more out that in?
Have you ever been on a sailboat? If you set your sail just right, you can take advantage of the wind that blows and get more work out than YOU put into the system. With the 3BGS, we have built a sail that collects the free flux that is all around us. Believe it or don't. I could care less. If you take the time to build it, you will see.
How does putting a capacitor across a diode raise the voltage drop that occurs across a diode? The voltage is lower on the output side - so where does the energy come from to raise it when you put a capacitor across it?[/font][/size]
The ambient itself raises the voltage on the output side plate of the capacitor to raise it to match the input side of the capacitor thus raising the voltage across the diode and negating the voltage drop across the diode. You did not supply this energy - the ambient did so for you. This is the kinetic ambient background aether that Tesla talks about. Because it is kinetic, you can get it to do work for you by leading it about via electrostatic charges. That's all we are doing. [/font][/size]
[/font][/size]
I know you've seen the thread at EF. You wouldn't come on there and spout this drivel because there are FAR TOO MANY of us on the 3BGS thread who have seen this work and YOU know it. Instead, you come over here where few people know about it and try and put a damper on getting folks involved. Silly man! It's far too late for THAT!![/font][/size]
[/font][/size]
We have already figured out that you can flip the magnetic polarity on a battery, and when you do, you create a negative resistor that sucks in the flux and allows you to use it as energy to run loads. All we're working on now is a consistent method for flipping that magnetic polarity. Too many of us have seen it happen with the 3BGS for anyone to stop us now. Too many of us have had setups that ran for hours or days or weeks. With the folks we have working on it, it's only a matter of time, and then people like you who couldn't cut their way out of the box they are in with a chainsaw will be left way, way behind. [/font][/size]
Dbowling
Hoppy,
The link to the schematic we are using is here:
http://www.energeticforum.com/renewable-energy/10610-3-battery-generating-system-78.html#post235538
And it is post 2335 on that page.
Be advised that things may change drastically very shortly. We have learned that reversing the magnetic polarity on a battery SEEMS to turn it into a negative resistor, and it self charges. If you keep a load on it to prevent it from charging, you can continue to pull the flux out of the ambient environment. FOr how long, we don't know yet. So we are focusing on two things...finding a consistent way to flip the magnetic polarity on a battery, and seeing how long this negative resistor will last. Way may only need ONE battery.
Dave
