0 Members and 23 Guests are viewing this topic.
JohnGalt_USA
Quote from: Dbowling on May 05, 2008, 08:26:29 PM
I will be charging up four batteries now and then discharging them through the Kill-A-Watt to see how many hours of power they put out. And doing it again and again. Kilowat hours of electricity is the "standard" my electrical engineer friend wanted to see.
David, are you ever going to give us an update?
tagor
Quote from: miki02131 on May 19, 2008, 02:10:02 AM
All,
If David device fails, this one will work almost beyond a doubt:
http://www.overunity.com/index.php/topic,1310.new.html#new
My first replication ended up in meltdown due to the high output current and heat. I monitor my input current was at about .5A. The output was probably in the hundreds. We finally have a winner. It is called VSG. Please replicate.
Thanks,
Miki.
can you put some pics and results of your setup ?
mrl
The theory as explained at this web site may be the reason why it works.
http://www.kz1300.com/hfgc/
There may be an RF DC modulation that causes a form of super conducting effect.  The motor acts like an  in circuit modulator of the DC line, which then lowers the apparent resistance of the circuit.  If this is true then you may be able to achieve the same thing my using a modulating transformer in place of the motor.
Drannom
All,
Thanks,
Miki.
After going there and read everything i think it's better to try to reproduce David Bowling system, Hartiberlin explain very well how to tune it, the audio interview is long , it's a radio shack motor with gear box like those one use in a robot, i guess anyone can find a little dc motor and look inside to see what kind of spark he get
i have perform many discharge in my carbo fusion test, and now i look for the easy way
i may succeed with big capacitors instead of acid batterys
David Bowling got a success, Hartiberlin solve it and will win the price ! yeah
David is not there anymore, we do not need more input to go forward
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
