Get electricity from thin air.
Started by nightlife, May 01, 2008, 05:12:09 AM
Lakes
This brings memories of me building my first crystal set many, many years ago, I taped the wire to the ceiling! :D
toasted
Interesting idea.
Would be cool to power gadgets and stuff with it.  like my ipod ;)
Not so sure we could power the world with it. But there is always hope.
theb3e
Pretty interesting stuff! I watched a mini doc and it was this ham radio guy that had large antenna's that he had to ground out because the voltage he was gathering with his antenna would fry his radio components.. I wonder if getting an antenna high up in the air then hooking it up to a circuit like this would yeild more?
What if you could hook it up to your home wiring (copper ground wire) to turn all the grounds in the house into an antenna?
I love trying out little things like this.. so off I go to put together the circuit!  I think I have everything here anyway.. why not!
Pardon
Quote from: nightlife on May 13, 2008, 01:04:31 AM
Pardon, did you try to hook it up like this following picture shows.
yes i did try that also. and i tested a voltage of only 2.3 vdc at the car coil then added a cap to catch a higher voltage and it never went over 2.3 volts no matter how i had the circuits connected i could not even charge a AA battery.
i tested my APM circuit at a record of 157 VAC and still no amp's present
and i still can't do a darn thing with it. bummer :(
