Get electricity from thin air.
Started by nightlife, May 01, 2008, 05:12:09 AM
pese
Quote from: nightlife on May 01, 2008, 05:51:33 AM
pese, one comment posted said they used the power to operate their R/C car. I am assuming the car is one of those small remote control type of cars. If they did use it as stated, then I have to say there is some power "behind it". The same with the video as it showed to recharge a cell phone. I am not saying it works as good as they say but I think it's worth checking out.
This way ?
NO.
I working over 50 years with this what you doing now.
you can enough find out over this in OU
or google out. You will find more, than anybody can explain you.
Pese
nightlife
 pese, don't get me wrong, this is not me doing this and i am assuming that if you have been working with this for the lenth of time you have stated, you must have been working with some sort of fox hole radio design and or at least that may have been your initial interest.
Have you ever tried to incorporate a earth power concept with it?
Doug1
 Would it not depend on what the thing was tuned to receive? The wire he used in the video was only 2 inches or so of magnetic wire. I do not know what radio frequency that would be. Surely it could be set up to work off some stray emissions that are unwanted other wise. Or even off something in a range of frequency from solar radiation. Any way it is a very small package few parts and easy to assemble for experimentation. It might even function to work off emf waste from running other appliances. As a way to conserve waste. Mix it in with a spark discharge gap on a coil that has fast response to collaps it's field through a load it may even make dirty ac.
pese
this circuit, can take any frequencies (from 50/60kz line frequency
(you ca see this on oszilloscop if you connect 1 meter "arial" tothe input,
uf to VHF/UHF region of frequnciey by using 1N34 1N60 enz.
if this circuit is not "tnued" = spread-band, alltogether + static voltages, call alow
to read on an high impedance voltmeter voltages (even in hundreds volts).
I seen hundred diagrams, and proven (if i was child ,and my father examized and learned me)
If you connect an low imedanze analoge Voltmeter , or use only 1000 (100) ohm Load resitance
in parallel to you meter, you will see , that the reed voltages go low near ZERO !!
So only you have "absorbe" some mycrowats , with this system.
It is strong aenougt , to "tune" some frequency, amplify this, ande
hear "radio-nusic" by example.
If you wil use, to power an cristall-radio (1 k ohm Earphones must be driven) You need an
Local station in "near" .
If you will "ligt" an bulb, you must "sit" in front of an stron Medioum or Long-Wave station)
This work. I have done this over 50 years ago.
To drive an car , as TESLO and minimum 3 other people have done this
1930 to now(!) its need more knowledge, that you "trie" an i myself dont know.
Pese
ramset
If he's using a 2 inch dipole  increase the gain with other 2 inch dipoles at the standing wave ratio for max reception /power [focus the energy like a magnifying glass]    Chet  PS Pese is this idea a waste of time[seriously]
Thanks Grandma
