Critique Solicited
Started by noonespecial, May 08, 2008, 08:55:41 AM
noonespecial
I have 3 concepts that I would like to present for your consideration. I'm specifically looking for constructive criticism.
This is the first concept. Hopefully, self-explanatory but I can describe the action in a follow-up response.
Alexioco
So when the left-hand side descends around the little wheel, it slides along that slope causing the opposite side to go out?
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
shruggedatlas
Quote from: noonespecial on May 08, 2008, 08:55:41 AM
What are you trying to make it do?
Alexioco
lol I am trying to make it swing like a pendulum, sorry if I?m talking nonsense, I had no sleep last night :p
It looks an interesting device, but you see how the weights are attached, even though they are more to the left, I am not sure weather that will make a difference because no matter where that weight is, it is still attached to that very spot, also the bottom weights might have to be slightly more heavy in order to keep those weights in position...
noonespecial
Sorry....I had to go out for the day....
I've removed the center wheel and connecting rod because they were just there to show the transfer from lever action to rotary motion.
Overview:
There are 2 cylindrical weights...A and B. I've made them out of 3/4" copper tubing filled with solder. They sit on platforms that are allowed to tilt about 5 degrees left and right above the main beam. Both platforms are tied together by the lower rod beneath the main beam. There is 6" of travel from left to right. Weight "A" is 3" further out from the pivot point and weight "B" is 3" closer. There is also a counterweight hanging under each pivoting platform that is fixed to the platform.
Function:
As shown, weight "A" will fall lifting weight "B". The counterweight beneath weight "A" is pushed outward by the falling weight and the angle on the base. This in turn tilts both platforms to the right (they are tied together). Weight "A" rolls inward 6" and weight "B" rolls outward 6". Weight "B" is now further from the central pivot point than weight "A" and a mirror image of the previous action occurs.
