I'm not one to get prematurely excited...but can someone explain this
Started by Cap-Z-ro, May 08, 2008, 06:34:41 PM
Cap-Z-ro
Here's what I got so far...
I have 2/two 9vdc batteries..running at about a 6 and 8 vdc charge respectively.
The 6 vdc battery is now reading 11.40 vdc
The 8 vdc battery is now reading 13.09 vdc
Both are still climbing and nothing is getting hot.
Here is the interesting part...I am charging both of them on separate circuits...and all II am using are caps and a transformer on one arrangement - and 2 caps and a small DC motor on the other.
The motor doesn't run while all this is going on.
Does anyone here have any idea what this is ?
I wonder if it can be used to amplify current gotten from an aerial or an earth battery system ?
If these circuits amount to anything significant many of you here can take some of the credit...I learned a lot about the function of things from observing exchanges of ideas and theories in various threads.
Regards...
Creativity
(can u check accuracy of your multimeter?just the thing i was trapped time ago with multimeters...its battery was going dead.)
Blues it through your outstanding life,leaving more than just footsteps behind (1999 B-stok by me).
By being intensively responsive to what others say,i do run a risk: I open myself up to the opinions of others.i will,at times, have a great understanding for their opinion.Sometimes,i will even change my own opinion because i realize that the other person is right.This "risk" i do not run if i am unresponsive to what others say.
Feynman
Alot of times that can be caused by internal state of the battery... the only way to know for sure is to do load testing on the batteries.  Maybe you can post schematic?
Cap-Z-ro
I don't have a working scanner to post a diagram...is there any simple downloadable program I could use.
It would be good to get it out there so others are able to work with it.
I can't understand where the power is coming from...or why nothing is heating up...and I didn't think a 9 vdc battery could hold what is now 13.11 vdc and climbing...after an accidental shorting when measuring both systems. :)
Regards...
FatBird
Cap-Z-ro
Please post a drawing of how you have everything connected.
Thanks.
