FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
gotoluc
Quote from: LarryC on May 23, 2008, 05:04:18 PM
@gotoluc,
Before Thane's thread, I was developing an easy build version of Jack Hilden-Brandt magnet switching motor. My versions used the same shaded pole motor, cut up similar to what you did, except it would have required 3 shaded pole motors to get it fully working. Your Z rotor design is better. But the magnet switching setup that I used can easily be added to your unit and would increase the power by 3 to 4 times, and also the coil kickback.
The motor with magnets picture, has completely lifted the weight hooked to the fan and the rotor is completely in the air gap.
The motor without magnets picture, shows it cannot lift the weight at all.
On the motor closeup, you can see that I have an iron washer between the stator lamination and the 1" X 1/4" neo. This is to cut down the over saturation. The rest of the steel is just to complete the flux path, it doesn't have to be pretty or lamination, just a path to stop flux jumping to the stator.
The magnet are stuck N on one side of the stator and S on the other. When the coil is not energized all the flux goes thru the stator under the coil. When the coil is energized in the same N S as the stator, both the coil flux and the magnet flux is forced thru the rotor, and both kickback when released. The force formula is Flux squared. So double the flux and you get 4 times the force.
I hope you can set this up, as it would be very interesting to see the results on your electronics.
Anyone wanting to review some well done charts and statistics on a magnet switching device can check out patent 6369479. The motor is currently being built in Japan for motorcycles.
Regards,
Larry
Hi Larry,
thanks for sharing your project. That is so cool that you have done something so similar as I have. I will look into your design and see how well it would work in my design. Do you have Skype in case I have questions. If so you can pm me your username.
Thanks
Luc
LarryC
Quote from: gotoluc on May 24, 2008, 02:25:56 PM
Hi Larry,
Thanks
Luc
Hi Luc,
Sorry, no Skype, but I do have free long distance from the US to Canada. So you can pm me with your phone number if you want me to call.
The main problems with all these magnet switching devices is keeping the saturation problem down, by adjusting the magnet flux and the power to the best level.
If you look at the graph, FIG. 26 on the patent (6369479), it shows the SEPARATING FORCE at different CURRENT level for the electormagnet along and 5 different magnet thicknesses plus the EM. The cross section of the devices lamination is 10MM X 15MM.
Some results are very interesting. At the .4 amp level the EM's force along is 10KG and with the 5MM thick neo it is almost 40KG (4X). And as the amps go up the force curve starts to level out. Also, the smallest and the largest neos have the least benefit.
My design is a different from the patent or JackH's, but all of the magnet switching device are just getting that smart magnet to change to another path of least resistance and getting your EM flux to go along for the ride. So if you can't put a magnet in the middle, put it on the outside, small neos are cheap.
Regards,
Larry
PS: I use www.google.com/patents for US patents.
gotoluc
Hi All,
Please find an updated video of my Dual Pole Single Coil motor test 3, which now has a new commutator. In this test I am also collecting the Back EMF and showing it has usable power.
See it here: http://www.youtube.com/watch?v=T_uP2DDTLFQ
Stay tuned for more.
Luc
gotoluc
Hi All,
THIS IS A MUST SEE
Here is a Youtube  link of  a guy that just got in touch with me since I posted test 3 of my motor.
He is getting an interesting effect using a loose magnet inside a plastic container that he inserts in a air coil.
However I don't understand his language? Stefan can you please look at this and see if you know his language.
Link: http://www.youtube.com/watch?v=dUBf-zoV9Tg
and here: http://www.youtube.com/watch?v=YOrx_yGKIQ8&feature=related
Luc
petersone
Hi Gyula
could you sugest a value of cap.C1,I'm building the the trigger you kindly suggested.Thank again.
happy hunting
peter
