FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
DrStiffler
All things are possible but some are impractical.
gyulasun
Quote from: petersone on June 01, 2008, 03:08:44 PM
Hi Gyula
I don't known if I am right or not,I will simply try it.
I always try to work out why it won't work and not bother why it will.
The reason I feel it won't work is have the same poles approaching the coil at the same time,one perm.and one induced.
I'm winding another coil with thinner wire and a "box" section as I believe that is the best,hope to get a higher voltageto better swich the diode.of course the odds are well against me,nobody has betten lenz yet,as far as I know.
Thanks for your help.
happy hunting.
peter
Hi Peter,
I think the only sure answer is to test the theory in practice, no arguing can substitute experimenting so I am pleased you continue tinkering with this question.  I goofed in my last suggestion with replacing the iron piece with a permanent magnet: it would not insure any Lenz reducing effect. But I still maintain all my other reasonings written before that, including a tiny magnet behind the iron piece for cancelling any magnetization from the main perm. magnet.
rgds,  Gyula
petersone
Hi   Gyula
Thanks for your comments,I've wound another coil and will do some tinkering today,let you know the out come.
happy hunting
peter
eddy
Quote from: nightlife on May 13, 2008, 11:27:44 AM
Bedini and Bearden are the closest so far as far as I can find but then again, they most not have understood the forces at play because if they did, their motors would have been over 200% efficient.
It is a mater of understanding the forces as well as understanding how to manipulate them properly. All the above were trying to produce more work with two forces without properly utilizing either force. The only true over unity device ever built is the magnet and nature has even produced them but yet we have not properly utilized them. Bedini and Bearden were the closest thus far and they both left out three very important things.
I shouldn't post this but what the heck.
One very important thing they are not utilizing is both poles of the coils. While they are using one, the other is being wasted. Both can be utilized. Once both are utilized, the motor becomes 100% more efficient.
The other is the proper utilization of the magnets. They are only utilizing one half of the face polarity when they could be utilizing 100% of both face polarity's. This can be done if you truly understand how they work. This adds another 100% efficiency to their designs. It only adds 100% because you have to use both poles of the coils to properly utilize them.
To do this, you need to place one magnet next to another but with opposite polarity's facing up. This has to be done in two different arrangements but they must me arranged in the opposite, meaning, if you have one with the north first, the other has to have the south first.
Another thing that has to be done is the switching of polarity?s the coils put out. This has to be done between each pulse that the coils are supplied with.
Once this is all done, you will have what you all call over unity. There is your true free energy. Good luck and please don't be greedy.
Thomas N. Brown
36 Hodgson st.
Battle Creek, Michigan 49014
269-964
HI NIGHTLIFE, EDDY HERE, PLEASE EXCUSE MY IGNORANCE, THE MAGNETIC MOTOR SEEMS TO ME TO BE A VERY SIMPLE DEVICE TO MAKE AND POWER AN ALTERNATOR. THE POWER OUTPUT OF THE MAGNETIC MOTOR WILL SURELY DEPEND ON THE STRENGTH OF THE MAGNETS USED IN THE STATOR AND THE  OFF-SET ANGLE OF THE MAGNETS ON THE ROTOR WHICH GIVE DIRECTION OF ROTATION. THIS IDEA IS NEW TO ME, SO SIMPLE I DON'T KNOW WHY I DIDN'T THINK ABOUT IT BEFORE! THERE ARE SOME THINGS THAT BOTHER ME AND THAT IS THE POSSIBLE HEAT CREATED BY THE MAGNETIC FORCES AND THE MOST EFFECIENT ANGLE OF THE MAGNETS ON THE ROTOR FOR OPTIMUM PERFORMENCE. I DON'T KNOW HOW TO POST YET AS I'VE ONLY BEEN REGISTERED FOR ABOUT AN HOUR AND I'M STILL TRYING TO FIGURE IT ALL OUT. YOU CAN 'E' MAIL ME A REPLY I GUESS AS I HAVE AN INBOX. MAYBE I'LL BE LUCKY AND FIND THIS AREA OF THE SITE AGAIN TO CHECK YOUR ANSWER, HE HE!  ANYWAY A REALLY INTERESTING SITE. KIND REGARDS EDDY
petersone
Hi   Gyula
Everything working 100%,unfortunately I'm referring to lenz's law!!
Another stupid idea over with,however,there is lots of take about pulse motors,but I haven't seen anything about pulse generators!!! how about switching it off at the top and bottom of a ac wave form?
"Pay" for the rise in voltage,and collect the "free" flyback,haven't thought it through yet,but what are your comments in principle?
happy hunting.
peter
