Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
tosky
@OTTO
If you got a theory, and the theory is correct. You could buy the right material core from any manufacturer to build any size you want. Even custom made the cores. Others could also do experiment base on that theory. Theory is very important, You got it?
How do we know the theory is correct? Simple, generates electricity without input power supply.
otto
Hello all,
@tosky
Im really not a "theory man" but look at the 3 stack picture that worked fine for me without an iron core:
top and bottom collector connected together and rotating in 1 direction and the middle ring in the contra direction.
I was asking for cores of 1/2 in height because every control coil must have his own core. In this way I could stack 3 cores with the collectors and have again the height of 1 3/4" as the original height.
The controls wound of course not with lamp wires but with oridinary copper wires.
Thats the 3 stack version.
The other version with 4 controls is different:
there should be 4 cores, again 6" in diameter and connected as Mannix posted in his picture.
Otto
nickc44
Otto
www. mag-inc.com
800-245-3984
has 5 " OD and 3 " ID  1 " tall I have one Do I need 2 for this setup its a ring
You know I actually have 2
Draw it up for me and I will make it
Nick
Quote from: otto on May 27, 2008, 06:41:09 AM
Hello all,
@borg
there is a little problem with building TPUs:
the bigger the diameter of a TPU the more complicated to build it.
It was really a joke to build my 4" TPU but a 6" or even a 15" TPU is really a F....G job.
If I could buy cores that are 6" in diameter, Im sure that I would have a working unit in a short time because I know what and how.
I have at home a big motor. A working one. Hmmmm......to see the cores. Are there cores inside?? I never thought about it.
I would love to have cores that are 1/2" in height and 6" in diameter. That would be great. I have to google it. Maybe.....
As you all can see - Im a dreamer!!
Otto
PS: the more turns, the more voltage on my scope - the more on the output. BUT, not to much windings because then you have nothing on the output!!!
otto
Hello all,
@Nickc44
Just look at the 3 stack picture.
I dont know anymore where to send you my pictures because it seems that Im blocked somehow.
I sent also my schematic of the 4" TPU to Earl and Gustav22 but .....nothing
Otto
wattsup
@otto
If you ever have a chance can you please try something.
Make your yoke work, measure the power off the collector. Then cut the collector in half and reconnect the cut ends and test again. I need to now if the collector has to be absolutely in one uninterrupted length of wire, or if putting two in series makes no difference. This may have played a role in the ECD having so many ring connections. It would also answer a question for my FTPU build of having the top and bottom collectors from the same wire, not cut, so the strands of wire are unchanged.
