Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
innovation_station
Quote from: Chef on October 21, 2008, 10:30:27 AM
Yeah, we know already Dr. Antimon. It will work, and just "One little special moment and you and your home are dust...".
I am already reported YOU to police. I think you are a terrorist.  :o You want to see peoples to die!  :-\
this is compleat bull shit!!!!
I HAVE TOLD YOU DO NOT CASCADE IT .....  IM STILL HERE DUH!!!!!!   MAYBE THIS JUST AINT FOR EVERYONE.....
BE SMART WITH THIS YOU WILL HAVE NO PROBLEM I HAVE BEEN RESERCHING IT A LONG TIME AND HAVE NOT BUILT TILL I KNEW I WAS SAFE....
SO THERE IS ABSOUTLY NOTHING WRONG WITH THIS ENGERY SOURCE....
BUT IF YOU HAVE BAD INTENCTIONS FOR THIS POWER BE IT KNOWEN IT WILL HAVE ITS WAY WITH YOU :o :o 8)
IST
PLAY SAFE ...
sparks
    @Chef
    If you got a microwave and a piece of copper wire do this.   Take about 4" and curl it up so the two ends are facing each other.  You need some enamel on the wire and a nice clean cut.  Put this on an upside down plate you don't care about.
Then put a little water on the plate near the gap which should be about an inch.  You can put a second coil inside the first to help things along.  Put the whole thing in the microwave.  Turn her on.  It will take about 3 seconds for the filament in the microwave to warm up.  Then watch the water burn in blue white patterns and the standing waves pop the water making a high voltage corona discharge noise.
    I know what is going on here because I research shit like this.  I don't waste countless hours putting this that and the next thing together and doing this and that to them then try to find an explanation for it.
    Another thing you can try is converting radiowaves to light using a 4watt cb radio at 27mhz.  You take the output from the cb and connect it to a piece of copper magnet wire wrapped round a 40watt uv flurescent bulb.  Take the copper shield from the coax and drop it in a glass of water next to the bulb.  Key up the mike and the bulb lights up.  No filament heating or themionic emission or voltage across the tube.  Just electro-magnetic wave reflection through the bulb that excites the mercury vapor into plasma mode.  You use a steel clip at the end of the shield wire and no light.  Cause all your emwave energy is setting and resetting the magnetic field instead of turning the glass of water into a capacitor/antennae.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
innovation_station
Quote from: Chef on October 21, 2008, 12:00:08 PM
That's the only problem!  ;D
No offence man!  ;)  :)
i am the least of this worlds problems....
and a good part of the solutions ... imho
the world is a mess if you havent noticed ....
dont positives attract??  might this be why the earth is getting HOTTER??
ist
btw you will never move forward till you look back ;)
sparks
   GK
    Don't even think about bringing that generator of Ed's home for evaluation by an expert.  :)    Any chance Ed had room for an electric motor underneath it.  High frequency generator driven by a lowfrequency motor?
Think Legacy
Spread the Love
Grumpy
Quote from: Chef on October 21, 2008, 11:25:06 AM
Do you want to talk here about your theory why it will work for sure? You don't have one working, I bet you never saw one working personally, so you need to understand that clearly, if you can be sure, it work!
Are you going to show one working?
        -Frank Edwards
