Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
MACEDONIA CD
hi  bolt
i thing i anderstend you  i have made something  about 5 days ago  and is like you are say...........
ABOUT ROTATION <THERE IS NOT ENY KIND OF ROTAION FILD THERE  OF  ONE  WAY DIRECTION   TO MAKE  PRODUCED  <HIS T.P.U  > DC OUT VOLTAGE
I HAVE ANTHER EXPALNE IS NOT HAVE ENY KIND ROTATION THERE
<IS SIMPLE WHIT COMPLICATE WORDS I WHILL SAY NOW
       <IF YOU HAVE SOME  PONTENCIAL DIFERENTS IN THE  SOME   ???  THINGS INSAID THE  TPU  << YOU WHILL HAVE  DC VOLTAGE OUT>>  WHIT NOT IMPORTANT HOW YOU WHIL MAKE  PULSING THERE WHIT TO INPUT  COILS
<NO ENY KIND OF  PRECISIOS  ELKTRONICS  CONTROLERS  WHIT  TO MAKE  PROPERLY PULSING  3 COILS  OR ATHER THINGS LIKE <PULSING  1 2 3 >  COILS SEPARATEDLY   TO MAKE  LIKE  MOVING FILD IN ONE DIRECTION TO PRODUCED    THE FINAL  SECRET  OF TPU HOW IS TO PRODUCED  DC VOLTAGE
    I SAY NOOO  IMPORTANT THE PULSING  OR SINUS WAVE RAID COMBINATION  FOR SOME   1 2 3  AND AGAIN 1 2 3   LIKE YOU MAKE  DC VOLTAGE
NOO
                                  THE T. P .U   @BOLT  I THING IS  LIKE PONTENCIAL  DIFERENT ??? THINGS  HO  HAS ABLE TO PRODUCED   DC VOLTAGE  TO T. P U
TO SAY SOME MORE  PRECISLY TO POINT THIS EXPLANES UP HERE
THE SMALL TPU  WHIT ONE PERMANENT MAGNET WHIT  62 VOLTS
IS  T.P.U  HOW WORKS IN THAT WAY  WHIT POTENCIAL DIFERENTS  ??? THING
YOU ASK WAY MAGNET WHEN IS OUT OF T .P U  THE VOLTAGE IS AUTO  DROP DOWN
BEACOUSE THIS
MAGNET IS  FOR  TUNING MAX. HIS OSCILATOR FOR INPUT ENERGY AND YOU ASK
WAY THE  DC VOLTAGE IS DROPING SLOW
I SAY BEACOUSE IS HAS <POTENCIAL DEFERNTS
THAT REASON   <NO  FOR MAGNET  REMOVING IS  DROP  SLOW>
WHENIS MAGNET OUT OF TPU THE OSCILATOR IS WORK  LOW WHIT SMALL ENERGY
S.M SAID THE VOLTAGE IS DROPING  BEACOUSE<THE FILD IS SLOWW DOWN THE ROTATION LIKE JET ENGINE  TURBINE <<<NO>>
IS POTENCIALS THERE
THE ATHER <FOR BIG T. P.U
IS  THE SAME  DEVICES  BUT WHIT DEFERENT  PICK UP  ENRGY FROM HIM
THE  INPUT PRINCIPE IS THE SAME FOR ALL TPU  OF S.M
BUT BIG T P P  HAS DIFEREN PICK UP  SYSTEM <<<<NOT LIKE SMALL   WHIT POTENCIAL DIFERENT >
   THING ABOUT THIS
I HAVE TEST THIS AND AND I HAVE PROVET TO ME  AND IS LIKE THIS
sparks
      Below is a diagram I'd love to hear some blah blah blah about because I don't really want to duplicate it.   I don't know if it was a coincidence or not but things got a little weird around my neck of the wood after this.   I somehow ended up with the anode of a crt tube to the iron coil as shown. This was a florescent bulb holder and what the heck lets make a coil while we're at it.   The hv didn't do much for the bulb but somehow I ended up with the anode on the holder.  The smell of ozone and a whistling noise alerted me to look under the block where the end of the steel holder were stuck out about an inch or so.  The block was in a grounded metal vise.  There were these two jets extending from the wire ends as shown.
Never seen anything like this before.  I've seen plenty of highvoltage sparks from all sorts of ignition transformers and ozone generator hvhf transformers but never this.   I stuck my paw about six inches away from the ends of these flares and it was cold.  It was sucking heat right out of the top of my hand and I could feel cold air rising up in the cup of my hand an flowing around the edges.
    I know there was enough voltage to cause local ionizaton of the air around the electrode ends but cold air rising is weird.  Anyone explain this for me.  We had a halo of low altitude clouds for the next week or two and a rumor of a machine that suddenly appeared in someones basement.  And an armored private convoy of some sort going around town.  Hope it wasn't my broken TV opening up a worm hole. ::) ??? :P
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
turbo
Cold air is normal and you can feel it like you feel the wind that is why they called it "ion wind"
In the dark you can see it actually spit out this blue stuff like a fluid.
I have seen it many times.
If you "spray" it onto a plate connected to a meter and the other end connected to earth, earth shows up as being positive.
I have done many tests with this and it is also possible to transfer serious amounts of power to recieving devices, 100 Watt lightbulbs included, most of the time it only works when you first establish the connection and then apply the load, if you first apply the load and then the connection it won't work as strange as it seems and i have never found out why that happend.
Marco.
bolt
"Then there is the claim that the US Navy has had a similar device since the 1950's - this from a very good source.  I do not doubt this at all."
Nor do i this could have been replicated from around 1930 using relative simple sinewave technology and tube amps.  Its cousin is the hendershot device.
bolt
You keep telling me you cant make rotating magnetic field yet this circuit does exactly that. The L's are your control coils which are the grids in your cold triode. The big loop is the collector this should be LC with a cap on the output.
OR use a 3 phase driver which in effect is a single oscillator with phase shifted outputs. Both will give magnetic rotation.
