The Secret Of Gravity Revealed - Scientific Experiment Included
Started by 0ne, May 25, 2008, 10:37:44 PM
martinzurix
earth electro magnetic field and gravity not the same.  you ever try to electrise rubber baloon ?  baloon don`t have magnetic field but electric charge affect like gravity .   rotation of earth electrize earth matter with electric chardge and produce gravity effect
to make anti gravity  effect you need to produce electrostatic vacum above object.  you need to make electromagnetic vortex
0ne
Quote from: martinzurix on May 29, 2008, 08:08:04 AM
A balloon is made of electrons and protons which are electromagnetic and are effected by magnetic interactions.
b.t.w my theory is that Earth has a magnetic field because it's material compisition is made of electromagnetic particles. The mass of Earth is also a collection of mangets that attract. Not just the magnetic field.
Much like how a permanent magnet has a field that attracts, yet it has mass too, so if the magnetic force was gone in a vacuum the metal of the magnet would still attract. Because the atoms are magnetic too... sub-atomic attraction.
martinzurix
neodium magnets have external magnetic field but rubber don`t .
magnetic and electrostatic fields is in some ways similar but in some ways different.
electrostatic field affect all kind of mater, but magnetic only metals and other electro conductors
magnetic field is flow of particles and make pressure , but electrostatic field is something like vaccum and every particles is sucked in
0ne
Quote from: martinzurix on May 29, 2008, 08:45:46 AM
neodium magnets have atomicly aligned dipoles that are aligned in such a way to circulate extra magnetic force between the atomic particles magnetic bonds.
Rubber's atomic dipoles are really strong, so they don't align themselves with magnetic fields easly, or hold magnetic fields easy, and the magnetic domains of rubber are usualy unorganized?. But you can still use a magnet, or other material, and rub it against the rubber to magneticaly charge the sub-atomic particles inside the atoms themselves, which have their own little scale of magnetic attraction that I call mass attraction. This attraction at an unorganize fasion is why rubber would seem to have gravity effects.
martinzurix
if you see tornado then there are electrostatic effects too ... because rotating mass of water and air elecrilizes and produces antigravitational efeects that lead to easy lifting hauses cars ewerything ... this not only bay strong airflow (airflow and wind is electric based fenomena !!!)
