The Secret Of Gravity Revealed - Scientific Experiment Included
Started by 0ne, May 25, 2008, 10:37:44 PM
0ne
I am releasing information about gravity. It is all a lie. Gravity is nothing more the magnetic force. Magnetic force is nothing more than electric particles. A vast amount of particles are circulating around Earth. South polarity particles leave the North Hemisphere, and North polarity particles leave the South Hemisphere. Both particles bend around the entire Earth and are attracted to their opposite. This means in the North Hemisphere, North particles are raining down from the sky to Earth. In the South Hemisphere, South polarity magnets are raining down from the sky to Earth.
You can test this with a simple experiment. Read the following web page:
http://www.lawofmagnetism.com/sog.html
xee
@One,
Nice web page, but I think you are missinterprepting experiment results.  At most places, the Earth's magnetic field is not parallel to the ground. In fact it usually deviates a lot from being parallel. When you magnetize the wire it will point along the Earth's magnetic field (which is usually at an angle to the ground) and thus the wire will no longer be level. Also, once the wire is magnetized it will be effected by metal objects near it. To check to see if effect is due to gravity or angle of magnetic field, you will need to use moving coils and measure currents produced by moving in different directions (this is not easy to do). If the field direction indicated by moving coils is same as angle of wire, then the angle is due to magnetic field rather than gravity.
EDIT: I just realized that there is an easier way to show if it is magnetic field or gravity. Just turn the wire around 180 degrees. If it is gravity, then wire will stay in new position and the North end of wire will still be higher or lower as before turning. If it is magnetic field then wire will spin back to same position it was in before turning. You need to be very careful that wire is hanging from exact center so that one side is not longer than other side. Another way to tell would be to increase the strength of wire magnet. If it is due to gravity the angle should increase. If it is due to magnetic field the angle will remain the same.
loop888
hello, i have a question relating the antigravity experiment,
they say the magnantized metal levitates on one side, ok:
- if i attach a magnet to a metal the metal is magnatized in the way the magnet's magnetic field is, right?
if i just swicht the magnet's poles, the metal would be RE-magnatized?
     the magnatized metal would swicht poles too?
following that question:
let's supose i slide the metal from the gravity's webpage experiment througt several magnets forming a vertical line...
NS
SN       ^
NS  [METAL]
SN       ^
the metal should act as a pendulum?
saludos!  :)
Sprocket
Stan Deyo maintains anti-gravity was cracked over thirty years ago - interesting video lecture (8 parts)
http://www.youtube.com/watch?v=D8BCKcocgWE
