Bedini motor, debunked by MythBusters.
Started by Bulbz, May 27, 2008, 08:45:34 AM
mscoffman
I saw this one on u-tube. They use these honking big relays for running starter motors on cars.
Do you know how much current just the coils on those relays draw? I thought it was funny
when the guy says; "Yeah, you know you can hear it slowing down". It would been neat
the guy would have added; "Well, this ones not working we better send it back to the art
department and have them do some more work on it"...Bad show Discovery and MIT.
:S:MarkSCoffman
marcusishere
These free energy technologies will be used eventually. The people that create the resistence shown in the fake program of mythbusters will lose in the end. They are just in the death-throws now, thrashing about while they slowly die. They need to learn to accept change. If we hadn't accepted it before, we'd be riding around in horse and buggies.
Message to anyone blindly supporting the mythbusters - Go to yahoo group Bedini_Monopole3 and build the machine yourself .You'll see it works. I did it.
Message to anyone from the Mythbusters. Kiss my ....
utilitarian
Quote from: marcusishere on August 20, 2008, 09:47:20 AM
It works?  Do you mean that you can get the wheel to spin for a while, until batteries are depleted, or do you mean it runs forever, producing excess energy from apparently nothing?  If you mean the latter, well, maybe you should share your laws-of-physics-shattering discovery with the rest of the world rather than keeping it for yourself, because I am sure all the poor people of the world could use free energy.  If you mean the former, well, then Mythbusters is not so wrong.
marcusishere
On the machine I built ( which is not intended to extract a lot of energy but is a learning tool for open-minded people to build as a first project ) I started with 8 magnets on the wheel which was a 24inch bike wheel. In the tests I ran I saw an equal amount of energy leave the primary battery as entered into the charging battery and during the charging time (12 hours) the wheel was spinning at 60 rpm. So I saw free mechanical energy.
Then I added 8 more magnets to the wheel and I removed the thick grease around the wheel bearing and spreayed in 3 in 1 oil instead ( to let the wheel be much more free-spinning ). In the next test I saw a little more energy in the charging battery than left the primary battery and the rpm was 110. The charging time was 8 hours. So I saw a small amount of free electricity and a lot of free mecanical. - Not bad for an extremely simple setup that's not designed to extract a lot of energy !
My next plans are to build a much more serious and powerful little bedini machine called a window motor. Aparently this little baby self charges its own battery and produces seriously high revs with torque so you can use the torque. I'm going to build a little generator, connect it to the rotor and then see if I can feed the output of the generator back into the input of the window motor. If it works I'll be able to whip out the primary battery and just leave it running.
One has to try these things in order to know the truth. That's my philosophy for everything.
retrodynamic
Its some way to present a project or idea, to the Mythbusters?  For sure is one, but where? who? when?
Well the only thing I can do is to present here my stuff, and say pass the voice please.
www.geocities.com/gearturbine
Thanks. :)
