Bedini motor, debunked by MythBusters.
Started by Bulbz, May 27, 2008, 08:45:34 AM
jamesneal6927
To everyone who doesn't think this works.
I'm missing something here.  For about $50 you to can build one.
They work and produce large amounts of extra energy that can be captured.
If you want to doubt then do it after you have failed to get similar results.  Not before.
Also, please ask one of the people on the various videos.  They, to include myself, will be
more than happy to assist you in the construction.
These motors are real and real easy to construct; therefore the School Girl name.
You don't need expensive equipment to see the results either.  A cheap analog volt meter can easily display the results.
The parts list is extremely simple as well.
1- CPU fan from Radio Shack
2- Diodes
1- 9 volt battery (supply)
1- 9 volt battery (drained)
1- roll of 16 guage wire
1- soldering gun or just use a bread-board
1- transistor (SA5503)
1- LED (florescent)
1- Potentiometer
solder 1 diode to the emitter -> base - meaning the gray circle points to the base end.  The base is on the left side when looking at the transistor with the base/emitter on the high side.
solder 1 diode on the collector - this is the housing of the transistor.  That will connect to the charging battery positive.
Solder the Potentiometer to the base - this is the middle lead on the POTS
Solder the LED to the emitter and collector.  Make sure that the poles are in the correct direction.
re-wire the PC fan just like the videos show.
If you can't do this then you don't have a brain powerful enough to figure out any of the other topics on this entire site and should probably think about going somewhere else.
orbs
Quote from: alan on October 15, 2008, 11:08:41 AMMaybe it makes sense to you all, but not to me.
I would say most of the DVD is not much new information if one has followed JB's posts in the Yahoo groups and on his Web sites (the information is less scattered, though). The most interesting part is possibly in the last 10 minutes about how he sees how EM (electro-magnetic) fields restrict or enable RE (radiant energy) [according to my understanding, anyhow, but I might as well have missed that part earlier].
tagor
Quote from: jamesneal6927 on October 15, 2008, 05:57:38 PM
could you sell it for 50$ ?
if yes , I buy it
tagor
alan
I am not sure, but I think it (claims to) works similar to Meyer's Easer system:
Using a voltage only pulse to open 'energy aparture' in the hydrogen nucleus and releasing this energy.
Meyer also calls it EM radiant energy.
Could it be all the same? More important, does it produce the effects as claimed (is it real or BS)?
How do/did you evaluate this with the SSG? How is the skin effect correlated to RE?
