The Key To Perpetual Mechanical Motion
Started by 0ne, May 29, 2008, 07:48:43 AM
SINEWAVE
utilitarian, from reading your post i can deduce that you are incorrect...and have only experimented with '1' gate and used the wrong material.
1.properly utilized a downard introduction of gravity does not have to be implemented, for linear horizontal movement that is.
2.the moving object will exceed the tip of the v...it will not simpy stop at the tip.
3.it is not necessary to use a v shape topology.
4.the more narrow the corridor the faster the acceleration...but also the stronger the sticky point is.
almost all your statements contradict my actual findings.
broli, im not into giving my ideas up to people who dont take the initiative to discover on their own....but i would gladly share information once i see evidence that they have taken the initiative to actually try.
anyone who has the materials in hand can accomplish this.
one,:
1.mass can be variable
2.angles do not have to be pinpoint accurate
3.length of magnetic gap does not have to be perfect, it only assist in force...there are 2 magnetic gaps BTW (4 if you take into consideration each polarity)
4.creation of electricity may develop eddy currents, upon attempts of storage...i havent tried to store anything yet..but i visualize using inductance to overcome resistance...and not collecting the energy from the field generating the eddy currents...collect it at a different point...
Sudonym
The V in general is not necessarily the correct shape in and of itself, figure out how the fibanocci sequence and Phi are used to create the V shape you see in a tornado, or water going down the drain, and then recreate this movement.
utilitarian
Quote from: SINEWAVE on May 29, 2008, 10:50:17 PM
Save us the smugness, ok?  We do not need your charity.  You can keep your wealth of experimental knowledge to yourself.
The only thing you said that I find true is that yes, the moving object can exceed the tip of the V, but it gets pulled back immediately.  It is not possible to propel the object to the next V gate.
The more narrow the corridor the faster the accelration?  Not what I have noticed, and how does that even make sense logically?  If the legs of the V are long and almost parallel, that means that the next point up the line is only a little bit stronger, magnetically, than where the object already is, so acceleration is slower.
resonanceman
Quote from: utilitarian on June 01, 2008, 11:39:42 AM
Utilitarian
Save us the smugness?       Who  do you think you are speaking for ?
As far  as   it not being able to   propel  the object to the next gate   look at the   V circle in  reply 6    I count  3 gates.
Or this  one.
http://www.youtube.com/watch?v=T41_fkVfFNI&feature=related
It   travels  smoothly through 3 gates then stops  because there are no magnets installed  in the holes of the  4th gate
Do you have any other  disinformation or bad attitudes to share with us ?
gary
utilitarian
Quote from: resonanceman on June 01, 2008, 02:10:52 PM
Utilitarian
Or this  one.
Not sure what is going on there, but like I said before, if the Vs are arranged in order of increasing strength, then yes, you can escape a weaker V in favor of a stronger one.  The fact that the author of the video did not show a circle of Vs speaks volumes.  This concept cannot work.
