Fracturing Water Using High Frequency Electricity.
Started by gazzzwp, May 30, 2008, 02:09:08 PM
gazzzwp
Having seen quite a few videos on 'youtube' which impressively show water rapidly vapourising into HHO I am amazed that the overunity principle has not already been comfortably achieved.
For example looking at the videos made by Ravzz who posts on this board, according to his ammeter, 1.0A was a typical reading and I presume from looking at the circuitry in the video that the voltage is in the order of 12v.
This means that the input power Amps x Volts is extremely low.  Yet from looking at the enormous amouts of vapour produced it looks as if the amount of hydrogen given off would power a 2-3kw fire at least.
Am I missing something here - I was thinking of going ahead and building the Lawton circuit next week, to try for myself, however in the meantime any feedback on this issue would be useful.  Without a substantial power output the whole exercise would be pointless.
Gazza
Voltar X
Gazzwp: Ravi was putting that voltage and amperage onto the brushes of an alternator. What the actual output was, he didn't show. Very easy to do. Remember, you are preamping and pulsing the voltage before it goes into the alternator, which is the amplifier. Check out the vids by waterforfuel and how to rebuild an alternator on YouTube.  Hope this helps. Voltar
triffid
test, ,just wanted a link to this thread.triffid
triffid
I tried to build the paulo device which was posted on the internet.I was able to use a scope and determined that the one a friend had built was not working properly.I tried to make my own but my fingers were too big to make the tiny connections.So I bought a audio signal generator off of ebay.
I then started doing experiments using the audio signal generator as a power source.As I took the freq up from 1hz to 1100hz ,the resistance of the water cell went up.So I got bubbles but never a huge explosion of bubbles as the paulo device plans promised.As the freq went up the size of the bubbles grew smaller and smaller.It appeared that the volume of gas generated stayed the same.The size of the bubbles would get smaller and smaller as the freq went up.Finally I concluded that a audio signal generator is not the right piece of equipment for this experiment.I work in a major electronics firm and after discussing some of the problems I had with the engineers here,They said I needed a constant voltage power supply,with variable freq controls.As the freq went up the voltage of my generator went down.I never got that constant voltage generator.I used baking soda soln,then learned that the paulo device used only plain water.So I tested again but got the same results.Triffid
triffid
I did find that after a while I got bubbles at the lowest voltage and amp readings I could get on the signal generator.I guess the electrodes were well seasoned by that time.So I concluded that the high freq electrolysis of water is very efficent.I shut the generator off,no bubbles,I turn it on ,I got bubbles..At the lowest settings the knobs would go.Triffid
