Fracturing Water Using High Frequency Electricity.
Started by gazzzwp, May 30, 2008, 02:09:08 PM
TMGhost
Quote from: Jokker on June 16, 2008, 05:52:46 PM
Hi to all !!
I have started to make a replica of what Meyer did.
I Think this I my 5th test?.
What I have done so far:
I have created 9 Pipe, 360mm tall and 25mm wide, they have an inner pipe
with 1 mm space between them.
I also have made the control box, there are no secret about the box, it just create
Pulls in a lot of different freq. And I have tested the box, with the scope..
In my first test I was using an Atmel AVR Mega8  one chip computer, but it had some
Problem to generate freq above 1khz, so for now, I?m using the ?box?..
Made some test with the pipe:
If I connect 12 volt to one pipe just a sec, my Volt meter show 7 Volt and my Amp 16
(Max amp for my transformer = 9) when I then remove the power, my Volt meter
Quickly went down to 4 volt, and a little slower down to 2.4 volt, but from there, very slow..
So, the pipe works fine as a capacitor?
I think this is why the production doesn?t stop immediate when I remove the power.
The problem I have is to find that ?resonance? to do that I must have something to
Measure? like the volt, amp.. something..
Some idea ? what shall I look fore ?
In the prev. test I?ve done, Iv used 12v DC pulsed with box, when I measured the volt on the pipe
It only got 3.9 volt, but I got quite a lot of hydrogen (test with a lighter big bada booom.lol)
Some thinking:
If we think of this like a stereo with a mic, if a start the mic close to the speaker, I?ve got a
Mmm don?t know the word in English, but I think you know what I meant..
If I have quite small volume on the stereo, I must put the mic quite close to the speaker to get
The ?resonance?  BUT.. if I start with a strong volume, I immediate got a big  ?resonance?
Then I can slowly turn down the volume, and still maintain the ?resonance? ..
If you try this at home, you will see that you must turn down the volume almost to nothing
To break the  ?resonance??
Regards Christer / Sweden
Visual Echo
Quote from: Jokker on June 16, 2008, 09:12:41 AM
why not to use a audio out port to generate signal
Somebody find out if "AC/DC" produces as much gas as "Air Supply"
*** Visual Echo ***
Jokker
Why not to use ... ?
First thing about signal from audio out is... low power (laptop) even for transistor driving current, other thing is that u need to be good a computers ... there are very few programs and these do not work well. Programming is way complicated yea ?
Buy the ticket !
Take the ride !
TMGhost
Ok.. have redesign the control box, and put in a opto to separate the lo volt from my 260v DC
I have put a INPUT RECTIFIER DIODE right to my 240v ac and then got 260v DC, 10 Amp. from that to a BIG capacitor
to get some nicer volt?s. Have 2 new Transistors (MJE13009) 400v and 12 Amp.
So, the box will control the opto?s and they the power transistor, one for the pulsing
And one for the 0 to 260v control to adjust the effect
Do anyone now a easy way to maintain
the Volt, but reduce the amp ???
New test..
Want to see if I?m right with the ?sound? theory, that is, if we put in a lot of volt and amps
Then we got the ?vibrating? effect, and when we have it, THEN we can slowly turn down the
Volt and amp, with the same production rate, ore hopefully just something that is possible to measure with the volt meter?
TMGhost
HeairBear: Big thanks for the Meyer drawings, haven't seen them before !!
