Cancer cure, but FDA and doctors would rather have your cash and not the cure.
Started by b0rg13, May 30, 2008, 07:59:29 PM
z.monkey
Howdy Triffid and Helmut,
There is a food remedy for arthritis also.  Arthritis is caused by the buildup of uric acid crystals in the joints.  These crystals form a sharp needle like crystals so you can see why arthritis hurts so bad.  Cherries have a compound which breaks down uric acid and destroys these crystals.  I have know people suffering with arthritis and when they eat cherries they have almost immediate relief.  Fresh cherries, dried cherries, cherry juice, cherry jam, cherry pie filling, as long as it has natural cherries it will dissolve the uric acid crystals.
I hope this helps...
Blessed Be Brothers...
Goodwill to All, for All is One!
Cap-Z-ro
armagdn03
Actually the Dr Bob Beck device has very little in common with the working principles of the Rife machinery. It cures more than just HIV, in fact it is said to clear the body of every and any alien bacteria, parasite, virus etc. that is not supposed to be there. This is probably the most promising technology to be discovered, and should be followed. The method is known as In Vivo, meaning no blood need be removed, and is called Blood Electroporation.
Quote from: rbisys2 on July 10, 2008, 05:27:21 PM
< QUOTE>"... pathogens like virisis -are in the 300nm spectral range. Have you ever wondered why they use UV light to sterilize instruments? What is the wavelength of UV light?"
Funny you should bring that up.  Seems like they tried circulating blood thu a tube subject to UV to kill HIV.  Didn't work.  However the Beck unit based on a previous 1992 patent device does work on HIV.  The Beck unit is a modified rife technology device.  Cheap and portable. The doctors of the 1992 unit suddenly removed their unit from the public.  All this info is on rife.org.
I wish I could turn my brain off sometimes, then I could get some sleep.
helmut
Quote from: Cap-Z-ro on August 05, 2008, 09:53:45 AM
@Helmut
Lakhovsky coil info here...
http://www.copperhealth.com/
Let us know if it helps.
Regards...
@Cap-Z-ro
@eastcoastwilly
@All others
Thanks for Hints and Links
I have tried to eat lots of gelatine powder...but could not get a result.
Now i will try the Lakhovsky coil .  It is a simple coil from Copper wound around the waist.
And it is as usual : Nothing to loose ... exept some pain.
Thank you guys ;D
helmut
triffid
www.copperhealth.com says to use #10 guage wire.But I grabbed the nearest wire which was a flat two strand thin flexable wire that I could tie around my waist and I felt better 24 hours later.I don't think the thickness of the wire matters too much, just the diameter of the loop.Its really an "open ended loop of one turn".You do not connect the ends.I could tell after a week I needed another coil around the affected ankle.Again phone line solved that problem.So after a month of wearing both coils I realized the arthritis was gone.I have used only copper wires although something else might work
I decided not to take the chance.Stick with whats known.The plastic around the phone line keeps the ends from being electrically connected when you tie them.Good luck.I'm glad the knowledge is helping people here.Triffid
