I seem to have Negative Electricity but what do you do with it?
Started by gotoluc, May 31, 2008, 04:58:24 PM
zaydana
Luc,
I'm curious as to what happens if you removed the Neo and just put the spark gap on the actual core. Does the current draw go up, go down or stay the same?
wings
exnihiloest
Quote from: gotoluc on June 01, 2008, 12:48:16 AM
Hi all,
here is an updated video which has a much better result ;)
Link: http://www.youtube.com/watch?v=vsDccdEcPx4
Thanks for looking and if you think this is good share it with everyone you know.
Luc
Hi Luc,
Could you provide a schematic of your setup?
Paul-R
I can't get videos with my connection - but I am puzzled by
thsi "negative energy" concept. surely, energy is energy. It
cannot be + or -.
CTG Labs
Hi guys,
Can I just say that negative energy & radiant energy have never been proven to exist and there is not one experiment that can show them!
However, lets assume for a moment that they do exist.  With negative energy all effects are reversed (due to convergent energy flow rather than divergent).
In this case reading heat from a resistor will not tell you anything.  You cannot see it on a meter or a scope.
Lets say you connect up a bulb to a negative energy source, the bulb will be very bright and clearly (dissipating, if thats the right word with negative) energy, but when you read the meter and tells you only low current, and that is because the meter is only seeing the normal positive energy dissipation because a meter works on dissipation of energy not convergence and is infact a load in itself!
Resistors and other items likely to get hot will infact get cold because now the flow of photons is reversed, instead of photons being scattered away as energy to create heat in the surrounding space, photons act in reverse and are removed from the surrounding space and converge on the load (thus reducing heat in the surrounding area making it cold!).
You must look for these effects and do not do normal load tests as they will get you no where!
Regards,
Dave.
