HHO generator
Started by mrmechanical, June 03, 2008, 04:35:13 PM
mrmechanical
To start, I would like to say Hi to all, I am new here, and to HHO, but am certainly getting a crash course in HHO generating. So let me tell my story, and hopefully those of you better at it than I will be able to point me in a good direction to continue. I started with a clear generator kit from Hydrogen Garage, purchased a jar of KOH from Soapworks, and started the fun. I assembled the generator as per instructions, installed it in what I thought to be the coolest place in the engine compartment of my 1987 Nissan Sentra, hooked everything up, turned it on and drove away. I wish it was just that simple. I am a truck mechanic by trade, and love a challenge, but this is different. No matter how much I adjusted the KOH strength, it appeared that I would always end up with thermal run off, 150+ degrees and 25+ amps. I guess at this time I should say I live in south Florida (think HOT HOT all the time). I hooked a thermometer to the outside of the generator and found that even when not in use it would get to over 130 degrees (I think that's too hot). I tried various ways to keep it cool. I used a washer pump to pump the solution through an old copper transmission cooler, the temp stayed down, but didn't produce any gas. So I took the pump off and let thermal dynamics take its course, that didn't work either, the solution started to turn green, and I kept filling the cooler with HHO so it wouldn't cool it. Finally I relocated my battery to my trunk, and relocated the generator to a cooler spot in the engine bay. I enclosed the generator and mounted a 10" radiator fan above it to give good air circulation, I also glued aluminium strips to the outside of the generator to help with heat dissipation. Finally I also lowered my KOH concentration to 10 amps at start up, within 45 min will hit 20 amps, finally blowing a 25 amp fuse. Well I can't seem to get it to run below about 120-125 degrees (ambient right now is about 95 degrees and very humid). I am going to install a PWM within the next few days, and I am hoping that will help. So my questions to whoever can answer them are; What is a reasonable temp for the generator to run at? and Does anyone have any other cooling ideas?
God give me the serenity to accept things which cannot be changed;
Give me courage to change things which must be changed;
And the wisdom to distinguish one from the other
hunter
I had some similar situations, and I did install a PWM controller, that's helped a lot. Still heating up after an hour, but not that much than before, because I can turn the AMPS down. I?m going to buy a pulse generator, and that way my generator will not get that hot.
mrmechanical
Thanks for the response, I think I've figured out part of my problem, I don't have the generator shrouded properly, so I'm drawing hot air from the engine compartment, heating up the generator. I noticed while driving home that although the gen temp was over 120 degrees, amp draw was still only 11 or 12 amps. So ambient heat still seems to be an issue. I'll contiue to post as I progress
sigmaX
mrmechanical, et all:
I am following with interest your investigation / findings. I am building an HHO GENERATOR in the following days.
In my case, I am actually building two, and testing them on my "home lab" before inserting into the car. I will build one with 16 15x5 cm stainless stell plates, and another with a stainless steel wire going around a plastic plate (like the one it is being pictured in this website) ... I will measure up HHO generation / amps used etc. Any suggestions, are welcome, btw :)
Regards,
Enrique.
jikwan
zen is the art of seeing everything and noticing nothing
