DOOMSDAY!! December 21st, 2012
Started by bobo36us2, June 07, 2008, 03:30:13 PM
Drannom
a scientific explanation for 2012 from Arthur P. Summera
it is all about the Central Sun
quote from electrinium.pdf chap 3
you can get it here
<http://www.nuenergy.org/pdf/electrinium.pdf>
Quote...
In a study of the way Nature uses its electrical forces we should he mindful of all the things man
has learned about the characteristics of electricity. We know that light has no heat, that heat has no
light, that there are hundreds and possibly thousands of different electrical rays, each with its ow n
function. We know that an electrical force in one direction will have an equal force of magnetic energ y
to the opposite. We know that each atom has an electrical force equal to every other atom and is in
electrical balance with every other atom when under equal heat and pressure. We know that each atom
is alive with electrical force and radiates that force in all directions.
We know that an atom under direct radiation of the Sun or other body will take on an additional
force and then radiate the additional force. We know that the radiation of a force through a pathwa y
of resistance causes heat. We know that heat causes expansion of atoms which under the law of
electrical balance throws the heated atoms out of electrical balance with cool atoms. This will
cause electrical force to flow from the cool atoms to the hot atoms. The force given up by the cool
atoms must he replaced by their neighbors. This becomes a chain reaction and a circuit of flow i n g
electricity is established. To understand this more fully make a small electro-thermo couple as
described in your encyclopedia and play with it for a few minutes using an ammeter to measure
the flow. The secret of Nature?s great power is the electrical reaction of atoms under heat or pressure
and the resulting flow of electrical energy through pathways of electrical resistance. The electronic
system of the human body is extremely sensitive to this law. The slightest compression of a coil
by the touch of a finger or the expansion of a cell by heat sends an electrical current to our brain
to alert us.
Nature?s use of these forces is mainly very gentle and the construction of this beautiful world,
with its great variety of living things a delight to behold. It is small wonder that a great many people
want to set aside great unspoiled wilderness areas for future generations because this past century has
seen man at war with God and Nature and our world is so badly torn that she may not survive.
This has happened many times in far past ages and ancient records tell of great cataclysm, of walls
of water sweeping from pole to pole. Of the Earth shaking the ice fields free from the poles and
washing it down over the lands to sweep all life clean of the Earth. There are records of great general
earthquakes, the slaking of entire continents and the raising of new ones. Just outside Mexico City
are three burled cities built on top of each other. Each was destroyed by a water cataclysm and the
following city built atop the old. This shows that the land at that time was near sea level. Today it
is seven thousand feet above sea level.
These catastrophes have been accredited to an act of God, but they were acts of nature working
under the natural laws of the Universe. A cataclysm is caused when the magnetic attraction
between the Earth, the Solar Sun and the Central Sun become out of balance. Our Solar Sun being
the closest, pulls the Earth towards it. At the point of twenty-three and a half degrees from the due
north the balance again changes, the Sun loses its power to hold the Earth off center and the Earth
lurches back into position. It is this quick lurch that spills the oceans over the land and swoops it
clean of all life for a new start. The last time it happened it broke all the ice deposits loose around
the North Pole and washed them down over North America. The great Ice Age that was supposed
to have, occurred twelve to sixteen thousand years ago wasn?t an ice age at all. It occurred almost
instantaneously by a cataclysmic action of the Earth. At the same time a great wall of water rushed
from the South Pole over the other side of the Earth, washing all life ahead of it into the Arctic
Ocean. The Arctic Ocean is a graveyard of past life and it happened so quickly that many of bodies
were quickly frozen and when dug up today are in perfect preservation.
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
Sparky345
Quote from: Digits on July 28, 2008, 02:20:39 PM
thanks ramset man you are so right i think there are 900 diffrent christian believes who do i believe.
i think if we search hard enough we will find the right way.though one thing i somtimes wonder do you guys think that this earth wil sustain us for another 50-100 years.the end will have to come sometime.
i just fear that the day we see Los Angeles sink it is allready too late.
900 Christian beliefs? Nope. If they don't believe Christ is the son of God and the path to eternal life then they ARE NOT CHRISTIAN.
Mormons aren't Christian,  Unitarians aren't Christian, Even some that hide under the banner of United church of Christ, (like Obama's racist church in Chicago) aren't Christian.  NO baptism? Not a Christian. No communion? Not a Christian.
Profess that Jesus Christ is the son of God, get baptized and accept his blood and body, be born again, accepting his new covenant,  then stick to his Holy Gospel (word), don't get confused by those who preach the old bible and old covenant law. A Christian is bound by the new covenant, not the old.
"Make sure that no one traps you and deprives you of your freedom by some secondhand, empty, rational philosophy based on the principles of
this world instead of on Christ."
Colossians 2:6-8
"This people honors me only with lip-service, while their hearts are far from me. The worship they offer me is worthless; the doctrines they teach are only human regulations." (Matt.15:8-9).
"You must not love this passing world or anything that is in the world. The love of the Father cannot be in any man who loves the world, because nothing the world has to offer -- the sensual body, the lustful eye, pride in possessions -- could ever come from the Father but only from the world; and the world, with all it craves for, is coming to an end; but anyone who does the will of God remains forever." (1 Jn.2:15-17).
"Remember the maxim: 'Keep to what is written."  (1 Cor.4:6).
Now, as far as Newman goes, the guy is a complete fraud. He has scammed poor gullible people out of millions. This guy is NOT a Christian, he's a Muslim con artist.  He uses Christian talk to sucker in his intended victims, then plays the usual "MIB, government agents supressing me, etc etc. scam artist play book. Always check the list of " free energy scam artists" for these guy's history of scams, how they manage to escape the law by changing names, moving to different states, leving a trail of victims.
Sparky345
Quote from: Sprocket on July 28, 2008, 05:22:59 PM
Just wondering if anyone has dreams about any of this?  I have had several, over as many years, all involving water (lots of it!).  In the latest, I am watching a massive wave, still several miles away, heading for my home.  Another dream involves watching mass UFO landings. (hundreds, they're everywhere)  Is there anyone having similar dreams? - or should I just go back on the lithium! :D
All this gore-bull warming stuff, melting ice caps causing world flooding is a bunch of bunk.  There is no human caused global warming. CO2 is NOT a pollutant.  Global warming is nothing but a scam a vehicle to bring in world governance run by elite liberal/marxist dictators.
CO2 is one of the most abundant elements on earth, have you forgotten your grade 3 science?
to find that the majotity of scientists DO NOT support the global warming BS, check out thier site. Who are some of them? The same ones who's report (altered) was used by the  UN to begin this Koyoto accord scam.
http://www.friendsofscience.org/
About "the end of the world":
Read prophecy, it tells you how the end of the world comes about.
Here's a good place to give you an idea of what prophecy says, the signs that are right under our noses that you just can't see , largley because you haven't been looking for it.  After all, how would you know to look for if you've never read bible prophecy to begin with.
"The lasts days of Babylon" http://goodnewspirit.com/babylonintro.htm
Sprocket
Funny, you quote me but your post has no bearing on what I asked!  Also, your "born-again" christian zeal makes it clear that you believe only one reference to prophecy has merit - were the bible "word-perfect" (as you seem to suggest) and our only source of inspiration, we would be out looking for unmarried women who weren't virgin-pure to stone to death, not to mention the many other 'suspect' truths it advocates...
I would agree with you about the co2 thing though - imo, this is just a natural cycle the earth periodically goes through.  However, that does not alter the fact that whenever co2 has been this high in the past, an ice-age was in the offing - somethnig to bear in mind...
jibbguy
Whether or not you believe in the change being man-made or not... There really is no serious argument for global warming not happening: The Arctic Ocean being cleared of ice... The Greenland, Antarctic, and other glaciers melting, and the millions of square miles of "permafrost" tundra that have melted in Canada, Alaska, Scandinavia, and Siberia are proofs of it that even the most fervent "unbelievers" can't get away with denying.
Whatever political motives and undertones people insist on loading this issue with are besides the point of the existence of it happening. Blame the sun if you wish (although there is yet no real proof for this), but it is happening whether you like to hear about it or not.
Here is an irrefutable example of man-made change to our climate (but one even Gore and his people never talk about):
Around every city, there is a 2 or 3 degree rise in temperature from the surrounding countryside (or more). This is due to the albedo reflection of sunlight from roof tops and asphalt vs. natural landscape, as well as from industrial heat sources. This temp differential is more noticeable at night (because the man-made stuff holds heat better). You can see this shown every day on any local TV weather map showing urban areas. Considering how "urbanized" our world is becoming, with thousands more square miles being developed for habitation every year, it's an important and growing factor. But since nothing can realistically be done about it... Its not a cause celeb like carbon is.
There is a lot misinformation on both sides of this debate; and there indeed may be something to what you say about us ALL being manipulated: Imo, it is being pushed as a polarizing and dividing factor to keep the Progressive Left and the Libertarians from combining forces against the corporate fascists in power. As long as these two groups who agree on many things "dangerous" to the status quo are kept from forming a political coalition; the bad guys have nothing to worry about... Because they already "own" the  mainstream political parties. They keep us arguing among ourselves and just sit back and laugh at how predictable we are ;)
But that doesn't mean that global warming isn't happening for whatever reason: Or that the implied suggestion that we should do nothing about it is right either.  For instance: We all have a vested interest in keeping the sea levels where they are now... Even if you live well inland, believe me huge coastal flooding would ruin your day too...And be the cause of untold wars, very deadly pollution to the oceans, literally billions of displaced people, famine, economic ruin / global depression, you name it. Technology could solve this problem of rising oceans; if we can ever get over the petty squabbling (...and if they ever let us have free energy).
